oxy sensor in my cat?
Postby RED TOP MR 2 » Sun Jul 30, 2006 6:03 pm
hey own a aw11 mr2 and going to make a straight pipe to replace the cat noticed there is a sensor in the cat im guessing its an oxygen one. Do i need it?or should i just try and put it in the pipe?
RED TOP MR 2
Postby fivebob » Sun Jul 30, 2006 6:15 pm
It's probably not an O2 sensor, it's more likely to be the cat overheat sensor which you don't need.
Postby Ae92typeX » Sun Jul 30, 2006 8:37 pm
fivebob wrote:It's probably not an O2 sensor, it's more likely to be the cat overheat sensor which you don't need.
yep, just the cat sensor.
could always gutt the cat and bolt back in also.
Ae92typeX
Postby Adamal » Sun Jul 30, 2006 9:57 pm
The O2 sensor on the AW (And I'm guessing most 16v 4AGE's) is at the bottom of the extractors, where it joins the 2 - 1 section
Postby summin » Mon Jul 31, 2006 3:11 pm
Dont gut it, it sounds like crap.
Get a pipe or resonator welded in, much nicer tone. Oh and its just the heat sensor, just chop it off or earth it out.
summin
Postby Ae92typeX » Mon Jul 31, 2006 5:56 pm
true, but the cheapest option
Ae92typeX
Postby RED TOP MR 2 » Mon Jul 31, 2006 8:05 pm
need to learn how to weld for automotive class just gona make two flanges and weld a pipe in. then gona exhaust wrap it. Started today
RED TOP MR 2
Postby Jebus » Mon Jul 31, 2006 9:06 pm
Why on earth do you want to heatwrap just that?
Jebus
Postby RED TOP MR 2 » Tue Aug 01, 2006 9:53 am
gona do the whole exhaust cos it looks really bad and rusty
RED TOP MR 2
Postby Jebus » Tue Aug 01, 2006 9:58 am
Have you got the $$$ to waste? Wont be cheap, may as well just paint it, heat wrapping the extractors is the only part really worthwhile doing.
Jebus
Postby RED TOP MR 2 » Tue Aug 01, 2006 4:58 pm
my aw's exhaust only has about 1m to wrap wont cost to much. am on the second one as the first rusted through
RED TOP MR 2
Postby Adamal » Tue Aug 01, 2006 10:25 pm
Check your exhaust manifold isn't cracked around the #4 pipe btw. AW's have a bad habit of doing that for some reason...
