Piston/conrod disassemebly
Postby Mr Revhead » Sun Jul 30, 2006 10:33 pm
not that im aware of
Postby no_8wire » Sun Jul 30, 2006 10:34 pm
Hmm ok...just dont want ot snap the piston walls when I try to press out the pin! :lol:
no_8wire
Postby matt dunn » Sun Jul 30, 2006 10:35 pm
no_8wire wrote:Ok this is weird... I pushed the piston as far to one side as possible, yet I couldnot see and circlip...any suggestions?
Weird.
You are looking for the clip on the outside of the gudeon pin not in near the conrod?
Postby Bazda » Sun Jul 30, 2006 10:45 pm
its pretty much common sense, u dont go heat the crap out of them u just heat it up a litle bit at a time on a very light flame and a small tip like you would use for brazing, and it still takes quite a bit until the gudgens come out. Also you cant just aim the flame anywhere you want to.
and yes 7afe ones are a press fit, you will need to take them to a engine rebuilder who has a jig to get them out.
Postby no_8wire » Mon Jul 31, 2006 8:55 am
ok cheers...
no_8wire
