phat_levin wrote:if i was to get my cams reground by kelford, wat gains would i expect to get? and would vvt still work? my car is ae101 trueno 20v silver top......
CircuitLevin wrote:phat_levin wrote:if i was to get my cams reground by kelford, wat gains would i expect to get? and would vvt still work? my car is ae101 trueno 20v silver top......
Those guys are monkeys. Try getting some Toda or similar cams, proven track you know what you are getting. I looked into cams with them before I got the Toda ones, they had NO clude about the differences between a silver and black top and couldnt tell me even ball park what performance I would likely expect etc...
[/quote]RedMist wrote:CircuitLevin wrote:phat_levin wrote:if i was to get my cams reground by kelford, wat gains would i expect to get? and would vvt still work? my car is ae101 trueno 20v silver top......
[/quote="UK_Engine_builder"]
Toda cams are so agressive they munch valve train assemblies and lead to horrible 5th order harmonics and valve foat, meaning they have to supply horribly high poundage springs.
Piston designs are well.........well i just wouldnt.
ITB's are....poo.
And they are so expensive.
Any engine running all toda stuff is never anywhere up there in the power stakes.
TRD Man wrote:I'd have no hestitation recommending Kelfords.
In the 70's their reground cams were regarded as being more accurate than the originals they were copying.
I've used them on many occasions and would consider them to be the pick of NZ cam grinders.
Remember - Sometimes the quality of the advice you receive is directly relative to the quality of the information you provide.
CircuitLevin wrote:Personally I dont have a problem with Kelfords (other than the recent experience and the fact they couldnt work a cam on a Euro car I had as they had no idea what they were doing, kept it 2 weeks and returned it as they received it), locally there is not a lot of choice. Thats life. But I would rather a genuine Toyota billet used as the basis for the cam (like the Toda ones I got) instead of a rewelded one like Kelford would supply in this instance.
RedMist wrote:CircuitLevin wrote:Personally I dont have a problem with Kelfords (other than the recent experience and the fact they couldnt work a cam on a Euro car I had as they had no idea what they were doing, kept it 2 weeks and returned it as they received it), locally there is not a lot of choice. Thats life. But I would rather a genuine Toyota billet used as the basis for the cam (like the Toda ones I got) instead of a rewelded one like Kelford would supply in this instance.
Toda don't use "genuine Toyota billet". They claim to manufacture the billets in house.
Kelfords do supply Billet cams, weld built up or reduced base circle regrinds for the 4age.
In regards to your euro issue, it does sound a little off as my 4age cam is an Alfa grind. I would presume Kelfords could lay any grind on any cam if they so wished and the lobe allowed. I would say there would be other extenuating circumstances to this issue, perhaps cam hardness? I gather you supplied them with flow figures and an application?
Mr Revhead wrote:its club4ag so yeah beleive at your peril
RedMist wrote:You still havent answered my question in regards to your cams.
IE
"Posted: Thu Aug 03, 2006 7:27 am Post subject:
In regards to your own cam selection I gather the 288 9mm lift cam is your intake? IE 14111-101-032
