96 or 91 unleaded?
Postby gmacrae » Mon Aug 07, 2006 8:02 pm
...but putting 98 in your stock bigport 4age is waste of money and gas. An engine designed for lower octane (87mon=about 91ron) will run better on the lower octane fuel, will have more power, and will get better mileage.
If you're running higher octane in your car than the manufacturer recommends, advance the timing a few degrees to make use of it, otherwise you'll just lose power and economy. Better yet, plane the head as well :)
As a rule tho, turbo or very high comp cars with knock sensors should always run as much octane as you can get your hands on. If the ecu doesnt detect any knock, it will let the timing run as advanced as the map will go and give you better power and economy.
gmacrae
Postby Mr Revhead » Mon Aug 07, 2006 9:46 pm
yeah thats true, 9.4:1 is fine on 95
Postby mr pad » Tue Aug 08, 2006 11:20 am
gmacrae wrote:...but putting 98 in your stock bigport 4age is waste of money and gas.
You rekon? If the timing was set to +12d then I have heard that it will make a fair bit of difference to performance etc. Besides im sure these motors would have been meant to run on 98 or 101 when they came out of the factory.
mr pad
Postby Mad Murphy » Wed Aug 09, 2006 10:16 pm
Hmm, mine seemed to run a lot better when I switched from 91 to 98.
1989 Supercharged AW11, 1981 Sprinter GT, 1991 Primera s**tmobile.
Facelift AW11 Parts Wanted!
Mad Murphy
Postby Chickenman » Wed Aug 09, 2006 10:35 pm
Mad Murphy wrote:Hmm, mine seemed to run a lot better when I switched from 91 to 98.
But it would probably run the same on 95.
Baby Jesus
Chickenman
I Am The Walrus!
Postby gmacrae » Thu Aug 10, 2006 5:19 pm
Set the timing up around 14-15 if you're gonna stick to 98, and you should get a bit more power out of it
gmacrae
Postby Red_AE92 » Sun Aug 13, 2006 10:18 pm
basically if your car has knock sensors 91 will set them off and it will retard the ignition which means increased fule consumption and loss of power so yeh 96 will make your curren go alot better
Red_AE92
Postby Red_AE92 » Sun Aug 13, 2006 10:21 pm
and putting 98 in your bigport isnt a waste as they are designed to run on high octane the only 4age designed to run on low octane is a blue top
Red_AE92
Postby Mr Revhead » Sun Aug 13, 2006 10:23 pm
all TVIS 4ages are 9.4 compression
Postby Red_AE92 » Sun Aug 13, 2006 10:25 pm
yeh i read some where that the only four age designed to run on low octane is the blue top maybe it doesnt have knock sensors i don't no but the newer ones need high octane be it a tvis red top smal port red top what ever
Red_AE92
Postby NOLAW » Sun Aug 13, 2006 10:29 pm
what feul would you guys say to use in a 4agze (turbo)?
NOLAW
Postby Alex B » Sun Aug 13, 2006 10:31 pm
teh highest octaine you can find.
Postby Red_AE92 » Sun Aug 13, 2006 10:31 pm
as high as you can go which is 98 from a petrol station because then it shouldnt affect the knocksensors and as mr rev head said ur ignition timing will be sped up as much as possible from that fuel
Red_AE92
Postby NOLAW » Sun Aug 13, 2006 11:04 pm
oh yeh thought so :lol: :? :P
NOLAW
Postby Mad Murphy » Tue Aug 15, 2006 5:24 pm
It seems to but 98 is what my local gas station sells so that's what I buy. I don't really give a crap about the extra few cents cus its not as if I drive the car more than once a week.
Mad Murphy
