quick SC12 clutch q
quick SC12 clutch q
Postby slo_firo » Mon Aug 07, 2006 9:23 am
hey guys, as some should know i was trying to buy an sc12 from this site a couple of months ago to put on my mini - well is all on there and almost ready to start i just got 1 quick question i did a search but couldnt find what i wanted,
for the clutch do i just giv it a 12V supply? it needs to be on all the time as its a suck through setup
slo_firo
Postby sergei » Mon Aug 07, 2006 11:37 am
yep, 12v that is what it needs. it works the same way as any other A/C clutches...
Postby slo_firo » Mon Aug 07, 2006 2:28 pm
sweet cheers for that m8
slo_firo
Postby cr1mnl » Mon Aug 07, 2006 3:36 pm
fcuk thats gonna fly. whats been done to the motor?
http://toyspeed.blakjak.net/profiles/profile.php?id=708
Horsepowers for bragging, Torques for dragging...
www.ology.co.nz
cr1mnl
Postby slo_firo » Tue Aug 08, 2006 9:29 am
umm its actually an 1990 MG Metro 1300 engine, they come factory turbo all the internals are the same, the turbos just have a bigger oil pump (to feed the turbo) just dropped the compression a bit - also my crank pully is a little smaller than the levin the chage came off so it wont be running the full boost
what is the standard boost for a levin? it came off a fwd think it was about a 92 model
slo_firo
Postby cr1mnl » Tue Aug 08, 2006 9:20 pm
around 8 psi factory.
mint car man
www.ology.co.nz
cr1mnl
Postby matt dunn » Wed Aug 09, 2006 12:06 am
You realise that a S/C is a positive displacement pump so boost preswsure has nothing to do with what they run on a Levin.
Your engine is 300cc less and probably wont flow as well as the 16V head,
and the boost is dependant on the restriction of airflow through the engine,
so even though you are spinning it slower, you may end up with a higher boost.
Only real way to tell is to run it,
or find the VE of your engine and a really clever bastard to work it out.
Matt
Postby slo_firo » Wed Aug 09, 2006 9:04 am
hahah not the most clever guy - im guna start it up for the 1st time this week i hope, just gotta wire all my guages up and suss the top engine mount (to short the rear manifold is sitting to close to the firewall)
probly guna cut and thread it to make it adjustable
wish me luck!!
slo_firo
Users browsing this forum: No registered users and 26 guests
