Engine "coffee".
Engine "coffee".
Postby RS13 » Sat Aug 12, 2006 6:07 pm
I'm well aware of the symptoms of a blown headgasket, overheating, the milky "coffee" under the oil filler and cam covers, oil in the water and all that, but I've noticed that if I drive my car to work about 2 minutes away (yeah yeah, I'm a lazy bastard!) and then back home, I get that same milky coffee crap under the oil filler.
I take the car for a longer drive, get it to heat up properly and give it a bit of a fang, the froth disappears. I pulled my breather hose off today, found it was totally blocked up with oily gunk, it also had a little froth inside it too.. is this normal? I haven't noticed the car using much water (I had to top the rad overflow up from halfway when I got it, it hasn't moved much since), nor is it overheating at all..
I'm beginning to think that as I'm not heating the motor up properly, somehow moisture is getting into the motor (it has been raining the last week, plenty of moist, foggy air) and causing this. I've also had cars that emptied their overflow tanks within about 2000km, but definitely haven't had BHGs, why is this?
Opinions? Do I have a BHG or am I just needing to heat cycle the motor more often? Where does the overflow bottle water go if it isn't the head gasket? Or am I paranoid and in need of a thorazine drip?
RS13
Postby RedMist » Sat Aug 12, 2006 6:22 pm
There is a tonne of water... in air! When air is compressed the due point of air is lowered to the point it will condense on cylinder walls, and from there enter the engine. The only way to get rid of it is to evaporate it. Short runs won't do, as the engine won't get up to temperature.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Mr Revhead » Sat Aug 12, 2006 7:32 pm
yeah drive the bloody thing!
i empty about 500ml of water from my catch can every month or so
Postby RS13 » Sat Aug 12, 2006 9:07 pm
Hah, cheers guys. I really didn't want to have to crack my motor open after only a week of ownership, lol!
RS13
Postby RS13 » Sun Aug 13, 2006 12:50 am
One more stupid question (I seem to be filling up the tech section with them, lol!), I start the car up, there's a clunk, the cam cover engine mount has torn rubber and is sitting metal to metal, when I decelerate, there's a jolt for coming off the gas, then another jolt with a clunk.. ? Engine mounts aye? Whereabouts can I get them from, and how muchie?
I have to apologise, its' been so long since I've owned a fwd, I'm a tad rusty..
RS13
Postby Mr Revhead » Sun Aug 13, 2006 11:52 am
youll prob need to do all the mounts.
pretty easy to figure out where to get them from :wink:
and its not repco :P
