AE92 questions
Postby blessme » Mon Aug 14, 2006 7:34 am
still, i dont have the black box beside that plug, which is close to the small port, what does that thing work? does it necessary needed in the car?
blessme
Postby RS13 » Mon Aug 14, 2006 7:42 pm
I've had my "red circled thing" unplugged for the last few days, with the pipe coming from the throttle body plugged up. No huge difference, just idles a lot lower when you've got the lights/heater etc going. Doesn't seem to affect anything else that I've noticed.
That big black box coming off the intake.. is a resonator. Its' purpose is to quieten down the induction noise of the motor so basically = not really needed, unless you like it quiet..
RS13
Postby blessme » Tue Aug 15, 2006 5:16 am
thx bro, we lucky to get the facelift AE92, i have been lookin it 4 a while. and gonna get a full EXHAUST system from the engine, 4-1 header and hopefuli can get the nice cams and cam gears from the bluetops which r cheap and helps alittle bit. Still, any idea how to make a real air intake system to fit our car such as pipes that can put the plugs and vacum hose in, cheers
blessme
Postby escortman » Tue Aug 15, 2006 9:13 am
hey
iv got ae92fx with a pod setup and im pretty sure it only has one sensor pluged, can take a pik of it if u want
4x4 toyota blizzard offroader
escortman
Postby RS13 » Tue Aug 15, 2006 7:30 pm
Well I dunno eh, I've found that most off-the-shelf pod filters have a 3" inlet, whereas the 4AGE throttle body is only 2.5". I was looking at getting a 2.5" 45 degree silicon elbow, a length of alloy with a 2.5" to 3" silicon reducer, with a 3" pipe to the pod filter. Pretty expensive and a wee bit unnecessary, the other option is to just look harder for a pod filter with a 2.5" inlet, and just use the factory rubber pipe with the hole for the resonator blocked off, use a short length of 2.5" alloy piping to connect the pipe to the pod. Cheap, and will do the same job.
RS13
Postby Caveman » Tue Aug 15, 2006 7:38 pm
RS13 wrote:Its' awesome! I've owned all manner of FWDs, turbos, vtecs, and none have come close to the amount of fun I'm having with this one! Such a nicely balanced, chuckable chassis, very predictable, and outstanding turn-in.. could do with a little more power out of corners, but I'm working on it! Looks like blacktop extractors, pod filter setup, and a decent tune will be the extent of my mods for the time being, I'm looking around for a decent set of good bang-for-buck lowered coils too, if anyone has any recommendations?
What sort of suspension does it have? I have TRD coils in standard shocks (going to get KYB adjustables) and I get understeer. My ae100 has chris amon components and handles like a dream with slight oversteer but similar control to the ae92. I want the neutral/slight iver steer in the ae92
AW11 Track Toy
Formerly known as 1998
Caveman
Postby blessme » Tue Aug 15, 2006 10:39 pm
escortman wrote:hey
hey, r u able to get a pic to show how u did it,. coz i am try to get the pipe from trademe which cost about 80 buks
blessme
Postby escortman » Tue Aug 15, 2006 11:09 pm
yep can do will take some afterschool 2moro
in my ae92 i have Tokico adjustable coilovers handles really well feels like it hold the road really well only a couple times have i gone fast enuf around a corner and it was oversteer and only minor, cant wait to go around a track :lol:
escortman
Postby blessme » Wed Aug 16, 2006 5:24 am
what sort of the mods have u done to the AE92? what is the best way to increase the HP for AE92?
blessme
Postby blessme » Wed Aug 16, 2006 6:41 am
i have few bucks budget lying like 7, and just want rev better and runs alittle faster from the mid rev, any idea?
still, friend of mine is comin back here and he's able to bring me a pair of HKS cam gears( He told me the camshaft is to havey.........), does it works by the cam gears itself coz i dont have enough money to change the camsharft and the value spring all together, wat a shame.........
blessme
Postby escortman » Wed Aug 16, 2006 9:12 am
if ur talking to me all i have is a pod, extractors and 2 1/4in exhaust i spose its given it a little more, if u want to rev a bit better get some bluetop cams and if its your daily driver i would say no to aftermarket cams as they have bugger all down low as it is
between now and turbo all im going to do will be batt in bootso room for cold air box and some bluetop cams
escortman
Postby blessme » Wed Aug 16, 2006 12:46 pm
to escortman
thx, and u said the bluetops cam? what u mean is camshaft or camgears?, its not gonna be expansive tho, :lol:
i almost have the same setup for themods as u coz i just get a custom made 4-1 header, full 2.25 exhaust, K&N panel filter, for a facelift AE92, it get about 140-145HP,
and when u able to get some pics up and i can know how i gonna use the same set up to get a pod done :wink:
blessme
Postby escortman » Wed Aug 16, 2006 5:29 pm
the camshaft, i think i read they have slighty higher lift and longer duration
email me at escortman@gmail.com for pics or if some one can host[/img]
escortman
Postby blessme » Wed Aug 16, 2006 9:22 pm
or u can email me at sg_614@hotmail.com and i will try to load the pics up see if it works.
i hear the bluetop camshaft works on the smallport as well, not much but still works anyway for a little power gain.
blessme
