I assume that you can stack them as you go down the exhaust? as in from headers goes into resonator1 and from resonator1 into resonator2?
Also, if you have two that are from the same range of products... which will make it quieter, a bigger one, or a smaller one?
The reason I ask is that I have a nice 40 inch straight bit that will fit a couple of resonators into, and I was wondering whether I should get 2 19"(seems to be the biggest you can get), or some smaller ones.
