Was going to get TRD main and big end bearings, but the workshop guys adviced me is not worth it, genuine ones will do, so I am sticking with genuine bearings.
fxgt race wrote:I have slimiar set up,blacktop,valves three angle cut,new cams intake278 with 9.17 lift,exhaust 286 with 8.9 lift,new springs,and adjustable cam gears,silvertop rods,trd head gasket.I looked at toda but was a bit pricey for me and my engine builder cut me a deal for franklin cams for $1500 for the new cams,springs,and cam gears,I run a link lem and without a idle up she is a pain when cold,have to open bonnet and plug a credit card in the stop screw and the butterflys to keep the revs up till shes warm.had it dyno at 118kw 160hp at the wheels,or about 190 at the fly,I think it has a bit more as i had a stop under the excelerater pedal for the old engine set up and on the new engine it didn't allow the butterflys to open up fully,pity i didn't see this till after the dyno run and the $550 dollars later.
fxgt race wrote:your car does handle nice.
