strx7 wrote:if you're caldina is a ST215, be VERY careful if you up the boost. 18psi is piston melting territory in them unless youve got 98+ octane in them
99gtt wrote:The internal wastegate is the problem with boost spike,
there is not a single caldina i know of with accurate boost maintaining the factory waste gate.
99gtt wrote:The internal wastegate is the problem with boost spike, there is not a single caldina i know of with accurate boost maintaining the factory waste gate.
