rebuild ct26 or move up to a ct20b??????????????
Postby 135007 » Wed Aug 23, 2006 7:32 pm
the gt4 i brought has play in the shaft what should i do??
has any one got a ct20b?
can you get full steel shafts for a ct26?
any help would be greatly appreciated!
135007
Postby flygt4 » Wed Aug 23, 2006 7:41 pm
go straight to a ct20b , do not pass go , do not collect 200$ :wink:
can get steel shaft ct26 but they still are too small.
flygt4
Postby Dell'Orto » Wed Aug 23, 2006 7:43 pm
You can buy steel shafts for the CT26's, ~$300 I think...but if you were going to do that, you might as well highflow it at the same time, which will cost ~$1400 depending on who you go to, and if you were gonna do that, you might as well go to the CT20B brand new from Mr Revhead.
Conclusion: Get the CT20B, you wont regret it.
Postby Phothog » Wed Aug 23, 2006 7:59 pm
The CT20b is the better of the two...
but for 1989 technology the CT26 is a good turbo, parts are avail for them
(compressor & Turbine wheels & shaft Full rebuild kits,) and they are easily to upgrade compressor (ish i have done about 6-8 46trim T04E upgrades (even on a brand spanking new Landcruiser CT26)
where as the CT20b we cant yet get Compressor & Turbine wheels
all that is avail is kits.
conclusion. CT20b is the bestter turbo.
the Ceramic Gen3 MR2/ST205 standard road car will spool quicker, But cant really run high boost for toooo long.
the Steel CT20b from the ST205 Group A Homologation version (which is the one Mr Revhead can get & i have one in stock at work) is alittle lagger but can run higher boost more relaibly.
Phothog
Postby blackmk3 » Wed Aug 23, 2006 8:02 pm
would that same advice go for a 7mgte?
anybody put a ct20b on a 7m?
Nick
Mk3 MA70 Supra
blackmk3
Postby Phothog » Wed Aug 23, 2006 8:25 pm
blackmk3 wrote:would that same advice go for a 7mgte?
Nick
mmmm interesting idea.. i know of one person who used the turbine housing off the Gen2 mr2/ST185 Celica 3sgte on the 7mgte in a 4x4 hilux... the CT20b would work well ... but it might drop off up the top end.
Phothog
Postby 135007 » Wed Aug 23, 2006 8:37 pm
so has anyone got one they might want to part with? what can you expect to pay for one? will it bolt up to all the standard stuff?
135007
Postby Akane » Wed Aug 23, 2006 8:53 pm
The white 7M-GTE Supra with a "large" single entry CT26 with upgraded comp wheel, was gaining on my MR2, so I believe if you have one of those, you're way better off with an upgraded wheel.
Postby Phothog » Wed Aug 23, 2006 8:55 pm
135007 wrote:so has anyone got one they might want to part with? what can you expect to pay for one? will it bolt up to all the standard stuff?
Second hand ones go for about $500 - $800 ish ... Dont quote me.
Email Mr Revhead for a price on one... but they are about 6 weeks delvery
or if you want it now at work we have a brand spanking new one...Email me if you want a price.
The CT20b will bolt up in place of the MR2/Celica CT26 turbo
all that you need to do is remove 1 Stud from the outlet of the CT20b
or get a Aussie or simmar down pipe with the 7 bolt outlet.
Phothog
Postby blackmk3 » Thu Aug 24, 2006 7:43 pm
akane- ur refering to the one at last years toyota honda drags? that was a 1ggte...but makeing 270kws i must add...
Mk3 MA70 Supra
blackmk3
Postby 135007 » Thu Aug 24, 2006 9:58 pm
when taking the motor out is it easier out the top or out the bottom?
135007
Postby Akane » Thu Aug 24, 2006 10:48 pm
blackmk3 wrote:akane- ur refering to the one at last years toyota honda drags? that was a 1ggte...but makeing 270kws i must add...
Sorry, my bad, yes 1G-GTE that's right, I was dropping my jaws as to how a 2L "CT26" was killing me at high speed.
Then I found out that he has the "huge single entry" version with upgraded wheel, I didn't feel so bad after.
Postby blackmk3 » Fri Aug 25, 2006 7:12 pm
that was certantly one beast of a car forsure!
Mk3 MA70 Supra
blackmk3
Postby Gonad » Wed Aug 30, 2006 10:00 am
bottom, but you dont need to remove motor to replace turbo.
Go CT20B
1 X GT-FOUR RC
1 X ST191 Caldina
Gonad
