standard 4age idle lumpy (why?)
Postby scope » Thu Aug 24, 2006 9:39 pm
hello
my mate just installed a 4age into an ae70, started first pop but the idle is weird. it sounds like it won't idle and you're putting your foot on accelerate to give it some gas so it lives. kind of like the bridgeport idle but really slow. it doesn't die or anything, a real mission to take off on though! what could the problem be ? i got told that it could be a vacuum problem, is this right ?
thanks
chicken fillet and bacon with everything except onion and bbq, ranch and southwest sauces
current ride: 1980 mazda rx7 series 1
previous rides: ke36 corolla, series 1 rx7, ke30 corolla, ke70 corolla x2
scope
Postby l1ttle_d3vil » Thu Aug 24, 2006 9:46 pm
yep, could be a vacuum leak. check all your vacuum hoses etc.
Postby Ae92typeX » Thu Aug 24, 2006 10:05 pm
sounds stupid, but almost sounds like 2 plug leads are the wrong way round. Ive seen it done before.
Ae92typeX
Postby cosi » Thu Aug 24, 2006 10:10 pm
Spray CRC around the intake manifold, the engine will draw in the CRC from wherever its leaking and change tunes. You can pinpoint the leak this way.
cosi
Postby fangsport » Thu Aug 24, 2006 10:12 pm
purged the cooling system?
fangsport
Postby AE85coupe » Thu Aug 24, 2006 10:25 pm
my vote is on the cooling system, will have an airlock most likely, seen that a few times in 4ages
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby rwd_mayhem » Sat Aug 26, 2006 6:19 pm
it wont be cooling system because it does it when its cold and when its hot.
it revs between 2000 and 3000 rpm, it revs then completely dies then revs again, also in all gears itll speed up for a while then just slow down then speed up again, in 4th it speeds up to 60 then down to 50 then back up to 60 this is with my foot off the accelerator.
the wrecker thinks its either the MAP sensor or the throttle position sensor, i think itll be the MAP sensor because it got cracked by accident when we were putting the motor in.
P.S. 4AGEs are so incredibly awesome!!!! even with no exhaust it still quick as so much fun to drive even when its loud as $&#$% and everyone thinks your a wanker that keeps revving it when stopped at lights.
current: 1975 Valiant Regel
rwd_mayhem
Postby z0ton » Sat Aug 26, 2006 8:18 pm
I just had this exact problem in my ae82 4age. Try swapping the vacuum lines around and make sure their all hooked up.
z0ton
Postby fangsport » Sat Aug 26, 2006 9:12 pm
rwd_mayhem wrote:it wont be cooling system because it does it when its cold and when its hot.
they do it hot or cold if coolant is low
fangsport
Postby postfach » Sun Aug 27, 2006 7:33 pm
check idle control valve, i had a problem similar to this in my soarer.
postfach
