blackmk3 wrote:any of you guys got ABS? if so what did you do with the ABS speed sensor?
Yes you got it lathe work required.lathe work
blackmk3 wrote:Ae92typeX- you mean modifying the gearbox and fitting the sensor in? instead of running if off the driveshaft, how does that work?
thanks
Nick
Looonie wrote:Did you have to hack the front or the rear of the tunnel?
If its not a rear shifter box, and you have to cut the tunnel, then you will have problems getting into gears with your knuckles intact...
Users browsing this forum: No registered users and 41 guests
