After market ECU Security
Postby Adydas » Sat Aug 26, 2006 7:34 pm
Just want to know, If you install a ecu and have it tuned drive around park the car then Remove the ecu ( by unplugging the loom ).
Take it with you in ya bag or somthing for security your cant be taken or they cant break in and take it so to speak, Then you get back in car click ecu back into its mount and replug in the loom.
Would the car start? Will it remember the map? tuning? or would it lose its memory like a stock on?
Adydas
Postby atmosports » Sat Aug 26, 2006 7:41 pm
Removing an aftermarket ecu & carrying it round with you should be fine for the majority of aftermarket ecu's out there e.g Link,Motec etc, I've swapped ecu's from one car to another time after time without losing maps or any problems.
atmosports
Postby deaf_rattle » Sat Aug 26, 2006 7:57 pm
just get a decent alarm cliff.
it would be a pain to get to the ecu when the dash and stuff is in there anyway.
Postby Adydas » Sat Aug 26, 2006 8:09 pm
wicked that's what I wanted to hear.. matt that's an option but it has one and I would have better piece of mind.. not to mention mounted the ecu somewhat visible so it needs to be out of sight when we park..
I like where it is and secuirty of removing but... worry was would I have to take laptop to retune everything everytime I wated to secure car.
been a weekend car its nothing huge as won't really hbe parked but still
Adydas
Postby Akane » Sat Aug 26, 2006 8:18 pm
But what are you gonna do when you need to make a quick getaway from the cops when they raid your house? :(
But anyways yes it'll be sweet, most if not all aftermarket ECU's have Flash ROM's or EEPROMS or some kind of non-violate RAM.
Postby fivebob » Sat Aug 26, 2006 9:21 pm
You can use this as a security measure, but I would recommend fitting a mil-spec socket to the firewall and make up a short loom from the ECU to the firewall, and unplugging that each time.
The stock ECU plugs are not designed for repeated connection/disconnection and it is an expensive proposition to have to replace the connector on the ECU. That said however, the high pin count mil-spec socket/plugs are not cheap either. :(
Postby vvega » Sat Aug 26, 2006 11:51 pm
fivebob wrote:You can use this as a security measure, but I would recommend fitting a mil-spec socket to the firewall and make up a short loom from the ECU to the firewall, and unplugging that each time.
hes got himself a nice little m48 pro fivebob :D
im guessing he really whats to keep it :D
vvega
Postby Adydas » Sun Aug 27, 2006 12:29 am
the plug on it is beefy as, i dont see there been any issue unplug and plugging that in, and to be fair im not talking about plug removal on a daily or 4 time daily basis..
Im talking on the few times the car goes out IF i park it somewhere im going to be away and want to have added protection it wont go walkies i can get away with it without the hassle of needing laptop to re flash the map onto the ecu kinda thing.
Peace of mind that if i feel i SHOULD or HAVE to.. i can..
Adydas
Postby Dirtbag » Sun Aug 27, 2006 1:39 am
It certainly does one helluva job of immobilising the car :D, Im considering the same kinda thing for my rsm, but still gota figure out a way that i can take it off and put it back on the stand easily (plug will b easier than an ecu, a whole 6 wires! or something...)
AE101 GT-APEX Superstrut
My profile!
Dirtbag
Postby RedMist » Sun Aug 27, 2006 8:30 am
Adydas wrote:the plug on it is beefy as, i dont see there been any issue unplug and plugging that in, and to be fair im not talking about plug removal on a daily or 4 time daily basis..
Its all non volitile memory based. The technology that holds the BIOS on your PC. Leave your PC off for a year , and it may loose the time (battery based technology) but it wont loose the BIOS. I've seen references to as little as 10 years before non-volitile memory looses charge, but I would think most would be considerably longer.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Wildcard » Sun Aug 27, 2006 10:31 am
Unfortunetly nothing is fullproof - if someone REALLY wants your car, they will tow it, ECU or not.
Wildcard
Toyspeed Founder
Postby atmosports » Sun Aug 27, 2006 11:26 am
Tis True unfortunately a lot of late model cars with all the immobilisers etc in the world end up getting stolen by people with a tow truck, they just turn up, winch it onboard & no one says shit cause they think it's just getting towed for illegal parking etc & then they take them off somewhere & have all the time in the world to get round the alarm etc.
atmosports
Postby Adydas » Sun Aug 27, 2006 1:38 pm
Its not really at all going to be a security feature, its more beacuse its soemwhat visable due to its location, ( i tryed putting in glove box and all sorts but no way the loom would fit past the air con stuff etc ).
So if i parked it somewhere dodgy someone MAY be tempted to smash and grab just the ecu ( no idea why as i learnt TV do a good job securing the ecus in the event they are stolen, tracking serial numbers etc ) but it would be hassle on the day they took it getting the car home, as well as waiting for someone to try and use it so i can get it back.
Wicked to know, big help guys.
Adydas
Postby matt dunn » Sun Aug 27, 2006 10:19 pm
I had a link sit on the shelf in the garage for almost a year and it never lost it's program.
Matt
Postby vvega » Sun Aug 27, 2006 10:33 pm
thats because you kept stroking it and teh static energy keep it charged :D
/me hides back in the corner with his closed curcuit tv system\
vvega
Postby RedMist » Mon Aug 28, 2006 12:45 am
vvega wrote:thats because you kept stroking it and teh static energy keep it charged :D
Don't forget your tinfoil hat.
RedMist
Postby RedMist » Mon Aug 28, 2006 12:47 am
matt dunn wrote:I had a link sit on the shelf in the garage for almost a year and it never lost it's program.
Matt
I had a car sit on the shelf in the garage for almost a year, and it remained in exactly the same state I left it in... broken.
RedMist
Postby Dirtbag » Mon Aug 28, 2006 12:52 am
RedMist wrote:I had a car sit on the shelf in the garage for almost a year, and it remained in exactly the same state I left it in... broken.
that woulda bin one helluva shelf, or a really light car
My profile!
Dirtbag
Postby strx7 » Mon Aug 28, 2006 11:18 pm
I have the EXACT same problem......
Users browsing this forum: No registered users and 45 guests
