fivebob wrote:You can use this as a security measure, but I would recommend fitting a mil-spec socket to the firewall and make up a short loom from the ECU to the firewall, and unplugging that each time.
The stock ECU plugs are not designed for repeated connection/disconnection and it is an expensive proposition to have to replace the connector on the ECU. That said however, the high pin count mil-spec socket/plugs are not cheap either.
Adydas wrote:the plug on it is beefy as, i dont see there been any issue unplug and plugging that in, and to be fair im not talking about plug removal on a daily or 4 time daily basis..
Im talking on the few times the car goes out IF i park it somewhere im going to be away and want to have added protection it wont go walkies i can get away with it without the hassle of needing laptop to re flash the map onto the ecu kinda thing.
Peace of mind that if i feel i SHOULD or HAVE to.. i can..
vvega wrote:thats because you kept stroking it and teh static energy keep it charged
/me hides back in the corner with his closed curcuit tv system\
matt dunn wrote:I had a link sit on the shelf in the garage for almost a year and it never lost it's program.
Matt
RedMist wrote:I had a car sit on the shelf in the garage for almost a year, and it remained in exactly the same state I left it in... broken.
Users browsing this forum: Google [Bot] and 20 guests
