gearbox issues - k40(A series) on 4age
Postby rwd_mayhem » Tue Aug 29, 2006 7:31 pm
my gbox is getting nearly impossible to get in 1st when stationary while engine is running, it is impossible to get in reverse. its easier to get in2 1st while the car is moving. has my 4age already blown my standard 4spd? i havnt even driven it a week.
current: 1975 Valiant Regel
rwd_mayhem
Postby crnkin » Tue Aug 29, 2006 9:01 pm
check your clutch adjustment, but chances are its rooted. they dont last long if theyre in poor condition
deaf_homo "currrently yes"
crnkin
Postby MetalupYoAss » Tue Aug 29, 2006 9:32 pm
check your clutch adjustment, it might not be engaging far enough, ive heard of cases where you need to make a spacer between clutch fork and bearing, i think this is your problem.
MetalupYoAss
Postby frost » Tue Aug 29, 2006 9:40 pm
if you have blowen it ive got a k50 here from a ae85 that will fit the 4ag. pm me with offer. also it has no gearstick,
Postby matt dunn » Tue Aug 29, 2006 11:34 pm
MetalupYoAss wrote:check your clutch adjustment, it might not be dis-engaging far enough, ive heard of cases where you need to make a spacer between clutch fork and bearing, i think this is your problem.
Correction made.
The clutch is not letting go to allow the syncro's to work.
Clutch issue not a box issue.
How does the pedal feel?
Postby AE85coupe » Wed Aug 30, 2006 10:20 am
i had a similar problem, just put a spacer behind your thrust bearing to help it go foward a bit more, works a treat
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby MetalupYoAss » Wed Aug 30, 2006 10:27 pm
thanks
MetalupYoAss
Postby Lloyd » Wed Aug 30, 2006 10:33 pm
AE85coupe wrote:i had a similar problem, just put a spacer behind your thrust bearing to help it go foward a bit more, works a treat
Thrust bearing or fork pivot?
Postby AE85coupe » Wed Aug 30, 2006 10:38 pm
to be honest i can't remember exactly where the spacer was, i think it was just behind the bearing itself
i can't remember how k50's look, its been so long since i blew that box and threw it away haha
Details of car here
AE85coupe
Postby Lloyd » Wed Aug 30, 2006 10:40 pm
Oh, K50s. Stupid me is thinking more new stuff. You're probably right.
GO WORK ON THE 25!
And paint the engine bay :P
Postby AE85coupe » Wed Aug 30, 2006 10:43 pm
what Phils 25?
naa hes been trying to get me to help him with that for a while
i'm too lazy and i hate sanding haha
Details of car here
AE85coupe
Postby Lloyd » Wed Aug 30, 2006 11:20 pm
Heh, sorry. I keep confusing you with Phil on here for some reason. And he was talking about dodgy clutches tonight
Postby AE85coupe » Wed Aug 30, 2006 11:36 pm
all good man
just remember i'm the good looking one, that doesn't smell like anus
Details of car here
AE85coupe
Postby rwd_mayhem » Sun Sep 03, 2006 8:42 pm
yea it was the clutch, rangi'd it up by putting a hose clamp between the firewall and sir clip lol it works all good ay, also topd up the gbox oil.
rwd_mayhem
