Making it lower
Making it lower
Postby lyric » Sun Sep 03, 2006 6:36 pm
I have a 91 trueno, ive had lowering springs put in it but its not low enough for me.... its well above legal height atm. Ive been told that to make it lower i will need to have my struts shortened and then my springs compressed. Is this right? if so does anyone know who does this is chch, i know where to get springs compressed but not sure about the struts. What sort of price shld i be looking at??
Thanks
Charlotte
lyric
Postby crnkin » Sun Sep 03, 2006 6:56 pm
Chop it.
Just until theyre only just captive.
Then itll be mint.
deaf_homo "currrently yes"
crnkin
Postby Alex B » Sun Sep 03, 2006 7:23 pm
Well thats the rangi/ illegal with out cert way to do it anyway :)
Postby andyae85 » Sun Sep 03, 2006 7:25 pm
mate just did the same thing to his crx, i thing the place was cobra springs and was about $50 per strut and $50 per spring to get them shortened and compressed, its sitting at like 105mm now :D
andyae85
Postby Bling » Sun Sep 03, 2006 7:30 pm
andyae85 wrote:mate just did the same thing to his crx, i thing the place was cobra springs and was about $50 per strut and $50 per spring to get them shortened and compressed, its sitting at like 105mm now :D
10 bucks says it will be <105 by next wof :lol:
chamerlains will do the shortening and compressing afaik....
they do go to a place called Bellamy and east tho i think..... 58 falsgrave st, chch
Postby AceSniper » Sun Sep 03, 2006 7:42 pm
to start with what springs are you using?
AceSniper
Postby ke_25 » Sun Sep 03, 2006 7:59 pm
if you say cut springs are illegal with out cert.. technically so are compresed springs.. coz they have been tampered with frommanufacture...
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby andyae85 » Sun Sep 03, 2006 9:01 pm
appantly you dont need cert if your compressing aftermarket springs :? its just when ya modify standard springs well thats what the guy said at the suspension place
andyae85
Postby Dell'Orto » Sun Sep 03, 2006 9:07 pm
Go to Chamberlains and get them to custom make springs with the correct spring rate at x mm shorter to get to the height you want, then get them to shorten your shocks to match.
That way you get low without the uber gay cut springs ride.
Postby Mr Revhead » Mon Sep 04, 2006 12:09 am
check your measurments carefully
ae101/111s are suprisingly close to the legal limit stock.
50mm lowering often sees them too low for WOF.
if you have kings or dobis compressing them to close to 100mm will see you fail a wof soon.
Postby crnkin » Mon Sep 04, 2006 11:57 am
pyro_sniper2002 wrote:Well thats the rangi/ illegal with out cert way to do it anyway :)
its rangi, but not illegal,
Compressed prings are much more dangerous. Hmm lets all drop our centre of gravity, soften the spring rates and make them weaker... nice ;)
Cut them, and shorten the shocks if required, but do not compress them, complete waste of time and money, and your car will handle like shite.
crnkin
Postby Snoozin » Mon Sep 04, 2006 12:36 pm
Does compressing actually weaken the spring structure? I was aware they retemper them once compressed.
Either way, I still don't accept either method as a substitute for a custom wound spring or a replacement coil designed to fit into OE spring mounts.
Snoozin
Postby trueno_20v » Mon Sep 04, 2006 1:23 pm
ive tryed most of those on my ae101, do it proply 1st time with coilovers, :lol:
ADMIN EDIT: signature too large
trueno_20v
Postby Mr Revhead » Mon Sep 04, 2006 1:32 pm
im more than happy with the TRD springs on mine
id never want to go lower
Postby lyric » Mon Sep 04, 2006 1:45 pm
Its got cobra springs in it, to me its low enough at the back but the front is about 1 1/2 inchs higher. Looks kinda silly being so uneven.
lyric
Postby Dell'Orto » Mon Sep 04, 2006 4:57 pm
Mr Revhead wrote:im more than happy with the TRD springs on mine
Yeah but you're an old coont :P
Lyric - go see Chamberlains, they can do custom springs from your measurements. Much better than compressing or cutting.
Postby 4000GT » Mon Sep 04, 2006 5:35 pm
Just keep your eye open for used springs, they pop up all the time. I got some Apexi ones for my car not long ago...
Certainly cheaper than getting custom ones made, mine cost $200.
Some on TM at the moment.
http://www.trademe.co.nz/Trade-Me-Motor ... 502676.htm
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Postby Mr Revhead » Mon Sep 04, 2006 8:24 pm
haha the reason i wouldnt wanna go lower is its bloody low underneath already!
Postby AE85coupe » Mon Sep 04, 2006 8:32 pm
like crnkin said, just chop the suckers till just before they become uncaptive, that will get it nice and low 8)
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby Bling » Mon Sep 04, 2006 8:32 pm
I have cobra springs in my ae111, (lows or super lows), i'd not go lower as I'd not be able to park against standard height curbs or get my jack under front kit.
chamerblains make cobra springs afaik, so thats ya best option locally for custom height which is what you're after :)
