sergei wrote:Hey, this is flucked up I agree.
How many demerit points is that?
Maybe I should start organized crime in NZ to keep the cops busy, as they have nothing better to do....
56km is way below of accuracy of tyre size/speedo drive/speedo needle..
DO a little experiment, set seat a little closer to steering wheel than usual and right up, and see where you see the needle pointing (whilse stationary 0 will suffice), and repeat the experiment with seat little bit further and down, I'm sure you will get ~5km discrepency (in first example it will read below 0 and second above 0)... so will do moving your head left to right.
Speedo whatching kills.
Driving to slow also kills as it pisses right off other drivers and they start doing stupid things.
Nazis.
Adamal wrote:This is XRyanX. His car is so low that he has to drive over speed bumps diagonally. HARDEN THE $$% UP XRYANX!!
slighty_sykotic wrote:Jazza wrote: a whole heap of sh*t that must have taken a while to write
What the hell is your point? That you got done and others don't?
So?!? You are still doing a bad thing. Grow up![]()
This is a $&#$% toyota forum, $&#$% off to off topic, or better, leave.
--Sykotic
sergei wrote:well what is the difference between 50 and 56? Yes I understand that if speed is increase twice energy increases four times.
But in this case speed is not increased twice.
Don't forget that there is reaction time of about 0.2-0.3 seconds before you can apply brakes, that is saying that you already have foot on the brake.
I would say realisticly it takes about 0.5s to apply brakes considering that most of the time foot sits on the accelerator.
56kph is ~15.6m/s ~ 7.8meters gone before the brakes are even applied.
50kph is ~13.9m/s ~ 7.0meters gone before the brakes are even applied.
If some one jumps in front of the car at distance ~10-15m there is no way it is possible to stop. 15 meters is over 3 car length.
The only logical exit is to steer out of the danger.
When you are steering the speed is somewhat irrelevant (in this case the difference in speed is very minimal to affect an outcome).
In fact you can kill some one at 30kph.
It does not mean that speed limit should lowered.
If people would follow this logic, then forks, knives, lighters, matches, gas , power tools, and whole civilization would be banned becuase it can kill.
