Rwd Curren??
Rwd Curren??
Postby bbq1988 » Thu Sep 14, 2006 10:19 am
Hey Guys, Im just pondering a rwd conversion on a ST206 ZS-S Curren, has t been done before? (do they have the rwd tunnels from the celicas in em still??)
any ideas will be apreciated :)
Baked, Not Fried.
bbq1988
Postby RomanV » Thu Sep 14, 2006 10:37 am
If you've got $20k to spend, sure why not.
Postby bbq1988 » Thu Sep 14, 2006 10:54 am
mmhmmmm, still doesnt mean it cant be done..
Baked, Not Fried.
bbq1988
Postby Adydas » Thu Sep 14, 2006 10:58 am
he never said it couldnt, it was more a " Do you realise the extreem cost " when if you want a RWD car you could just buy a Toyota Supra ( if you wanting to stick with Toyota, or go nissan.
Adydas
Postby bbq1988 » Thu Sep 14, 2006 11:04 am
yeah i realise, but it would be somthing that is rear, and no ill stick with toyotas not nissans :)
Baked, Not Fried.
bbq1988
Postby Quint » Thu Sep 14, 2006 11:17 am
If i was going to throw money at a doomed project like this, i'd personally go with mk2 supra and put the engine and running gear from a gt4 in it.
In saying that, i don't have 10s of thousands of dollars to throw away ;)
Quint
Postby bbq1988 » Thu Sep 14, 2006 11:19 am
mmm, seeing as most gt4 running gear fits the currens it was just a thought.
Baked, Not Fried.
bbq1988
Postby wde_bdy » Thu Sep 14, 2006 11:24 am
bbq1988 wrote:mmm, seeing as most gt4 running gear fits the currens it was just a thought.
As far as I understand though the rear diff doesn't fit in without serious floor mods. Also the space taken up by the gearbox in a transverse engine 4WD is in the engine bay so you need a whole new tunnel for a RWD box. Steering rack will be in the wrong place too. If you are serious, full chassis it. Most cost effective way to address all the issues you have to overcome.
Callum
wde_bdy
Postby RomanV » Thu Sep 14, 2006 11:24 am
EDIT: D'oh beaten. Read above! ^
Nah the chassis is different with FWD currens and Celicas, they dont have the huge transmission tunnel, or space at the back for the rear diff etc.
Postby bbq1988 » Thu Sep 14, 2006 11:26 am
ahhh cheers for that, its what i was after in the 1st place :D
Baked, Not Fried.
bbq1988
Postby Bling » Thu Sep 14, 2006 9:14 pm
surely if you have a curren, you could have looked under it? :wink:
Postby Jazza » Thu Sep 14, 2006 9:33 pm
Im planning on doing it, i can get the fabrication i need done cheap and im just kinda collecting parts at this stage. It is a BIG job...
1996 Curren - On Tardme
1992.5 EG Civic - 101kw@wheels. WTB 4x100 6.5in wide rims.
Jazza
Postby bbq1988 » Fri Sep 15, 2006 10:01 am
lol awsome, yeah i could look under it... but didnt think
Baked, Not Fried.
bbq1988
Postby strx7 » Fri Sep 15, 2006 1:59 pm
bbq1988 wrote:yeah i realise, but it would be somthing that is rear, and no ill stick with toyotas not nissans :)
actually it'd be RARE. the drive would be at the REAR
Postby Mr Revhead » Fri Sep 15, 2006 2:23 pm
easy job
buy an st205
fit curren panels
thatll be the cheapest and easiest way
Postby Jazza » Fri Sep 15, 2006 2:30 pm
Mr Revhead wrote:easy job
buy an st205
fit curren panels
Not a direct swap :P Theres some minor differences
Jazza
Postby Mr Revhead » Fri Sep 15, 2006 2:35 pm
oh ok then
in that case:
buy st205 wreck
buy st206 curren
strip both cars
cut centre tunnel and boot floor from both cars and swap over. dont forget to have cert guy inspect all work. you will need a repair cert.
remove st205 running gear and suspension and fit into st206
rewire st206 to suit st205 ecu etc.
yes thats a much easier way
Postby RunningRich » Fri Sep 15, 2006 3:46 pm
That's all bollocks, you can do the swap in a weekend, I've read that on 6gc.net so it must be true.
Bah ha hah!
Richard
http://gtfour.supras.org.nz
RunningRich
Postby wde_bdy » Fri Sep 15, 2006 4:04 pm
Mr Revhead wrote:cut centre tunnel and boot floor from both cars and swap over. dont forget to have cert guy inspect all work. you will need a repair cert.
Interesting, I thought it it was a modification it was covered by your mod cert. Only needed a repair cert if the car is noted as being damaged?
Just curious as my certifier has never mentioned the need for a repair cert on my car with different firewall, trans tunnel and rear floor for IRS.
Callum
wde_bdy
Postby Mr Revhead » Fri Sep 15, 2006 4:10 pm
actually im not 100% sure on that
when i enquired about adding another air vent into the passebger side of my aw11 i went to a panel beater and they said that as it required cutting and welding of a structual section it would require a repair cert.
in hindsight i think a cert would cover it
