NA power coming - Not really
Postby Mr Revhead » Thu Sep 14, 2006 2:24 pm
BTCC were 300ish hp
theres been a TONNE of development done on the cossie over the years
power
Postby fxgt race » Thu Sep 14, 2006 2:43 pm
you just need to get everything right before going to a dyno,the power is there.Get a new 2 into 1 front pipe made up if you have a standard one as they are rubbish.check your butterfies are opening fully,check with the engine builders and see what they did with the cam timing.i did my petrol pump to make sure it was good and it wasn't.simple things that i missed before my first dyno run of $550 and changed them for another dyno run to gain another 17 hp at 175 atws.Your engine will come right .
fxgt race
Re: power
Postby BZR4AGE » Thu Sep 14, 2006 2:46 pm
fxgt race wrote:you just need to get everything right before going to a dyno,the power is there.Get a new 2 into 1 front pipe made up if you have a standard one as they are rubbish.check your butterfies are opening fully,check with the engine builders and see what they did with the cam timing.i did my petrol pump to make sure it was good and it wasn't.simple things that i missed before my first dyno run of $550 and changed them for another dyno run to gain another 17 hp at 175 atws.Your engine will come right .
Thanks for the encouragement :P
I will get around to it. money is an issue right now as i already spend so much. Hopefully will get some done by the end of the year
BZR4AGE
Postby NZ_AE86 » Thu Sep 14, 2006 6:19 pm
RedMist wrote:
NZ_AE86 wrote:What fuel are you using?
Avgas or don't bother!
With that CR, he's more than likely to loose HP with avgas.
I don't agree with that. 11.8 to 1 is too high for our shit fuel. Just my opinion though. :)
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby AE85coupe » Thu Sep 14, 2006 6:29 pm
out of interest Mr redmist
why would he lose power using avgas???
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby sergei » Thu Sep 14, 2006 6:29 pm
Stock 2ZZ-GE has 12:1 and it runs fine on 98....
Postby NZ_AE86 » Thu Sep 14, 2006 6:35 pm
You think it runs fine. :D Ecu will be pulling all the timing it can out and pushing more fuel through too.
Current rides;
1986 Levin GT
NZ_AE86
Postby RedMist » Thu Sep 14, 2006 9:13 pm
AE85coupe wrote:out of interest Mr redmist
Flame front is considerably slower running Avgas. Hence its ability to run higher compression without detonation. 11.8 in an open combustion chamber isn't that high. As such you are slowing the flame front, reducing the dynamic pressure at TDC and slightly reducing power.
Although I run avgas in both the Lancer and the Bunderson... I really don't believe in it. Both vehicles have been tuned to run on avgas and both have cooling issues and both are on the very edge when it comes to detonation. However I'd still be tempted to run one up on avgas and then retune it to run on 98. Bet the difference would be SFA, if not a small gain with 98.
I remember a mag article where they were forced to retune a rally car as avgas was being banned (I think its an ausi article) they made small gains by running pump gas which startled both the owner and the tuner.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby RedMist » Thu Sep 14, 2006 9:24 pm
BZR4AGE wrote:As for the dyno plot, I wish i have it too, but the guys didn't bother to get a print out because the gain was so little. all I know was before the engine was done it made 87kw atw, now it makes 100kw. Sorry redmist.
My blacktop with low compression in number 1 pulled 132bhp at the wheels on a dynajet. Thats a stock engine running a K&N and a Link LEM3. It sounds as if you have some issues.
30hp (which is at least what I would epect from that engine) might be hard to find in exhaust and a cold air intake. Perhaps an issue with cam timing?
RedMist
Postby NZ_AE86 » Thu Sep 14, 2006 9:28 pm
Yes I agree, Cam Timing or maybe just a poor tune? Plenty of people think/say they know what they are doing but really don't!
Current rides;
1986 Levin GT
NZ_AE86
Postby AE85coupe » Thu Sep 14, 2006 9:52 pm
is it running an aftermarket computer?
Details of car here
AE85coupe
Postby BZR4AGE » Thu Sep 14, 2006 10:10 pm
yes. Greddy E-manage ultimate with the following features:
- Speed limiter cut
- throttle setting
- warning setting
- ignition cut feature
- airflow output map
- anti engine stall feature
- acceleration injection map
-individual cylinder injection adjustment & indiviidual cylinder ignition adj map
- vehicle speed correction map
- coolant temp correction map
- intake air temp correction map
- rev limiter cut
- a/f target value map
- ignition adjustment map
- acceleration ignition map
- idle stabilization map
details are here
http://www.mohdparts.com/emanage/ultima ... index.html
BZR4AGE
