20v valve springs
20v valve springs
Postby Mr Revhead » Mon Sep 18, 2006 1:16 pm
ok had some springs tested
at installed length of 38mm and at 8.1 lift
seated, 8.1 lift, free length
silvertop 56lbs 79lbs 48.1mm
black top 63lbs 88lbs 49.2mm
TRD 51lbs 106lbs 42.3mm
Postby AceSniper » Mon Sep 18, 2006 2:32 pm
good info thx :)
TRD ones free at 38mm and 51lbs at 38mm install hight? :?
AceSniper
Postby Mr Revhead » Mon Sep 18, 2006 2:40 pm
of course not, no idea what your on about :oops: :wink:
Postby AceSniper » Mon Sep 18, 2006 4:29 pm
:oops:
my mistake ;)
AceSniper
Postby Bazda » Mon Sep 18, 2006 6:30 pm
those are faily high figures for blacktop one, all the ones i measured (ie 40 of them lol) at 8.1mm were like 60 lbs.
Postby Mr Revhead » Mon Sep 18, 2006 8:04 pm
all the springs i had tested were brand new
Postby Bazda » Mon Sep 18, 2006 8:07 pm
I dont see how the valve spring can loose that much, maybe his tester thing reads diff to ours..
u send a trd one to me i'll put it on my spring tester :D
Postby Mr Revhead » Mon Sep 18, 2006 8:09 pm
you pay for one and ill send you one :P
i may be keeping some in stock, so if i do ill send one
Postby Pies » Mon Sep 18, 2006 10:50 pm
*coff* done the 16v ones yet? *coff*
Current Rides:
Pies
Postby Logan » Tue Sep 19, 2006 9:24 am
Whats the coil bind on trd ones? ie how much lift can they take?
SR Sold. Onto Other Things
Logan
Postby Mr Revhead » Tue Sep 19, 2006 10:21 am
no idea.
ill go borrow a clamp and some verniers later on.
but from the looks of them id take some nasty cams to bind them up
