3Sge (gen3) to RWD
3Sge (gen3) to RWD
Postby Mr_procrastination » Wed Sep 13, 2006 12:44 am
Hi, just want to know if the gen3 3sge sump, (the two piece aloy sump) bolt patern is the same as the gen2.
And if anyone got one lying around im keen to take off your hands.
Thanks
Last edited by Mr_procrastination on Tue Sep 19, 2006 6:48 pm, edited 1 time in total.
Mr_procrastination
Postby fivebob » Wed Sep 13, 2006 2:37 am
They are not the same bolt pattern.
Postby Mr_procrastination » Wed Sep 13, 2006 10:37 am
Ok well if thats the case then not a lot of piont going down that track...unless their the same shape, then could just weld up the unused holes and drill the new.
What are people using for sumps on the gen3 then?
Are the altezza sumps conpatable?
Mr_procrastination
Postby slighty_sykotic » Wed Sep 13, 2006 11:14 am
Maybe gen 3 sumps?...
slighty_sykotic
Postby JustinSpiderholden » Wed Sep 13, 2006 11:40 am
Hey man ill send you some pictures of my speacil modifyed sump, hehe you should make one like it dersgined to keep those bearings well lubed all the time
JustinSpiderholden
Postby Mr_procrastination » Wed Sep 13, 2006 9:26 pm
Yea mate send some my way a :)
Anyone know if the gen3 engine also came with one peice steel sump ?
Im looking to change from a front sump to a mid sump to get behind the xmember.
Mr_procrastination
Postby Adydas » Thu Sep 14, 2006 1:15 am
I doubt this may be of any help to anyone, but here it is anyway.
If you want a more birds eye veiw of it let me know i can spin it around and snap you some pics.
Adydas
Postby fivebob » Thu Sep 14, 2006 4:51 am
Mr_procrastination wrote:Anyone know if the gen3 engine also came with one peice steel sump ?
No, they all had alloy sumps.
And what do you propose to do about the oil filter and the galleries that are in the front part of the sump?
Postby Mr_procrastination » Fri Sep 15, 2006 1:36 am
Yes well ive got three options i suppose<
Eather i can get a ta23 xmember,(does anyone have one lying around for me please), this should alow the sump to go infront of the xmember, hopfully not pushing the engine to far forward.
Or, look into converting back to the gen2 setup with the filter on the oil cooler, im making the usumption the block is still the same as the gen2 and perhaps the oil pump over the filter is differant to acomidate the oilways and filter, Ill have to have a look tomorrow.
Or just lift the engine 100 mm, yuck :?
Surly someone has done this something like this with the gen3 ?????
Ive done this convetion to a gen2, but this is some thing i didnt have to worry about.
Mr_procrastination
Postby Akane » Fri Sep 15, 2006 5:31 am
I guess you can go extreme and have a dry sump system.
Postby Mr_procrastination » Mon Sep 18, 2006 5:05 pm
Got a few pics of the oil pump cover on the 3sge gen3, can someone post up pics of the gen2 one and the block( under where the cooler is mounted), so I can make a comparison.
Looking to convert the pump to the gen two, or just bypass the oil filter on the gen3 version and mount the filter on the block with the oil cooler as the gen two did. Then modify a sump to fit.
Mr_procrastination
Postby Mr_procrastination » Tue Sep 19, 2006 6:48 pm
So at this point im after a 3sge Gen2 oil pump/engine cover, and sump.
(If anyone can tell me what there werth, or if anyone got the bits, that would be great).
Got the option to buy a complete,(slightly damaged) short block for a $100 bucks but dont really need the whole thing.
So your in put would be great.
Mr_procrastination
Users browsing this forum: Google [Bot] and 20 guests
