3SGTE (Gen1) Vacuum Leak - Driving me CRAZY!
Postby MrOizo » Wed Sep 20, 2006 7:11 pm
I have quite a bad exhaust leak and its driving me batty.
I was advised from a mate on here to spray/pour water around the area to listen for when the noise changes from sucking it up etc.
I found that when tipping water over the intake manifold, basically between the #1 and #2 injectors, i can hear a nasty sucking sound. What is there under there like in the ways of vacuum lines that might have popped off?
The leak only occured in the last week. Went down to Plamy region and only started playing up on the way home.
I'm thinking that the boost has popped it off or something along them lines.
Could it be something extreme like a manifolf leak? is this a worst case senario?
Any suggestions much appreciated!!@!
MrOizo
Toyspeed Legend
Postby MrOizo » Wed Sep 20, 2006 7:14 pm
Havign a look on the BGB - could it be something like the fuel pressure VSV
or the TVIS VSV? hmmmmm
MrOizo
Toyspeed Legend
Postby 85AW20v » Wed Sep 20, 2006 10:02 pm
Use a piece of 6-8mm plastic tubing to find exactly where the leak is. One end in your ear and as you move past the leak with the other end you'll just about crap yourself it'll be that loud!!
See ya
Simon
85 MR2 20v
85AW20v
Postby Lloyd » Wed Sep 20, 2006 10:09 pm
Put your head in and have a look. Easiest way to directly find it would be as above or spray brake cleaner or similar directly at where you think the leak is as it will make engine revs rise slightly when you get the right spot. Could just as easily be an inlet manifold gasket as much as a hose
What is the engine doing exactly?
Postby MrOizo » Wed Sep 20, 2006 11:09 pm
Simon85MR220v wrote:Use a piece of 6-8mm plastic tubing to find exactly where the leak is. One end in your ear and as you move past the leak with the other end you'll just about crap yourself it'll be that loud!!
Never thought of that!! will ahve a go tomorrow.
HRT wrote:What is the engine doing exactly?
Its got a really bas sucking sound. almost like sucking on a straw and the same noise as running out of coke is the sound it makes as i pour water on it.
When idling, sucks in/hisses, and when sitting at (Zero) PSI there is nothing and when boosting - leaks/hisses!
Have been looking around online and come across a few sites which pin-point the PS idle-up valves as being at fault.
I dont know if this would be it as the fault s really from taking the engine out and breaking it as it goes out or back in the engine bay.
When i take off one of the Vac lines from the TB, there is very little suction. will try follow that one tomorrow too.... not too sure where o look...
The area where i have been pouring the water and its been making the noises are arounf the red area in this pic:
This makes me think its something like the TVIS and or Fuel Reg VSV's
MrOizo
Toyspeed Legend
Postby MrOizo » Thu Sep 21, 2006 3:31 pm
OK found the $&#$% prob...
did this by disabling the vac feeds to the PS idle-up, TVIS and the diff locking VSVs. still a vac leak from the same area tho so not them
I have found that the seat of the injector is fuccked - gave the #1 injector a wriggle and the leak stopped :? is there anywhere that i could get one today at all?
forgot that i prob have work and there be none of that if i can drive there :)
oops my bad!
MrOizo
Toyspeed Legend
Postby sergei » Thu Sep 21, 2006 3:37 pm
LOL, thats what happend to me as well :), I just ordered new set of grommets from Warwick.
Pitty I did not read this post earlier as I would point it out straight away.
Was your car running lumpy aswell with the vacuum leak?
Postby MrOizo » Thu Sep 21, 2006 4:24 pm
sergei wrote:LOL, thats what happend to me as well :), I just ordered new set of grommets from Warwick.
not really... well possiubly - i thopught it was a loose connection causing to run rough. has done bofore.
are these readily avaliable in nz at all? on the phone to manakau toyota at the moment
MrOizo
Toyspeed Legend
Postby MrOizo » Thu Sep 21, 2006 4:26 pm
hmmmmm - $8.39+GST each/..
warwick... i call you now :D
MrOizo
Toyspeed Legend
Users browsing this forum: Bing [Bot] and 26 guests
