FXGT electric window switches
Postby redline racer » Sat Sep 23, 2006 5:49 pm
I am looking to buy a ae82 fxgt, it has problems with the window switches.
The problem is that the passenger window winds down but not up, to wind it up it needs to be wound up from the drivers master switch.
Is this a common problem?
I have been to the toyota parts department and the switches have been discontinued.
Do i have any other options other than secondhand?
redline racer
Postby $CENSLS1$ » Sat Sep 23, 2006 7:23 pm
Sounds like the contacts no the 'up' side of the switch have failed, could try some contact cleaner on it and see how that goes?
TeamPoon~Building Sex on wheels since '06
$CENSLS1$
Postby Sick Puppy » Sat Sep 23, 2006 9:22 pm
Is it the light silver one with the purple tints on the rear window? Auto? Just wondering...
Project thread here
Discussion thread here
Sick Puppy
Postby Ae92typeX » Sat Sep 23, 2006 9:42 pm
as $CENSLS1$ states above, i'd dismantle the switch, contact clean/ clean all switch points with some fine sandpaper 1st. If no improvement, check loom.
Ae92typeX
Postby redline racer » Sun Sep 24, 2006 9:23 am
Its a white one, no tints and its manual.
Yep could be a go'er cleaning up the contacts, although i have tried that on a 88 familia i used to have and it worked fine for a couple of days then the contacts became contaminated again.
No harm in trying tho
cheers for the replys, any more ideas let me know
cheers 8)
redline racer
Postby redline racer » Sun Sep 24, 2006 9:25 am
Also, does anyone know of possibly any other toyotas with a switch thats similar/ the same that could be adapted maybe? AE92 models?
redline racer
Postby Sick Puppy » Sun Sep 24, 2006 8:15 pm
Actually, try BJ wreckers in Napier- it was a fairwhile back (at least a year), but they had an AE 82 there- mostly intact...
Project thread here
Sick Puppy
Postby Pies » Sun Sep 24, 2006 8:16 pm
comon problem. had it on my old ae82 aswell
i have a bunch of ae92 switches available if you want one. otherwise just get in there with a screwdriver and keep "damaging" it till it works ;)
Current Rides:
Pies
Postby redline racer » Sun Sep 24, 2006 10:09 pm
Cheers, will try BJs wreckers
Pies- did you end up fixing your switches or just lived with them being tepremental?
redline racer
Postby Pies » Mon Sep 25, 2006 8:32 pm
i fixed them by playing with the contacts untill they worked properly again
Current Rides:
Pies
Postby $CENSLS1$ » Mon Sep 25, 2006 9:52 pm
redline racer wrote:Yep could be a go'er cleaning up the contacts, although i have tried that on a 88 familia i used to have and it worked fine for a couple of days then the contacts became contaminated again.
Did you make sure it was 100% dry before you put it back together?If not it will become contaminated again quickly,mainly because it'll catch anything that's in the air if its not dry.
$CENSLS1$
Users browsing this forum: Google [Bot] and 30 guests
