Differences???
Differences???
Postby TRD_ZERO » Thu Sep 28, 2006 5:17 pm
Are There any differences between the silver top and blacktop block? besides rods and pistons? Does the silver top have oil squirters? Can any1 help? And what was the verdict on 4agze pistons are they forged as bazda said that when his melted he showed someone in the know and they said they wernt forged but then Revhead said they are? Correct me if im wrong. I dont want the indepth lowdown i just want a straightforward answer yes they are or no they arnt. Thanks
TRD_ZERO
Postby themaleman » Thu Sep 28, 2006 5:34 pm
i read thers 3 types of 4agze pistons, from each era. the 88-90 (afm) 4agze had semi forged. then the 90-91 (map) has forged and ceramic coated pistons. and the 92-95 had snap ring, lightned and forged pistons. thats the OEM specs i believe
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby RedMist » Thu Sep 28, 2006 6:52 pm
There is no such thing as semi forged. How on earth do you perform part of a forging process? Is the other part semi-cast?
All ZE pistons are forged. Toyoya use a higher carbon content alloy to stop piston slap when cold. Hence they are forged pistons, better than cast, but not as good as a quality aftermarket forging.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby themaleman » Thu Sep 28, 2006 7:06 pm
yea i am not famalier with the forging proces, just read it here
http://www.club4ag.com/faq%20and%20tech ... _specs.htm
4agte ae92 Levin
a15 powered sj410
themaleman
Postby CozmoNz » Thu Sep 28, 2006 8:02 pm
RedMist wrote:There is no such thing as semi forged. How on earth do you perform part of a forging process? Is the other part semi-cast?
because the term 'Forged Pistons' has become reserved for aftermarket forged pistons only it seems....
Rayne For President!
CozmoNz
Postby Mr Revhead » Thu Sep 28, 2006 10:21 pm
:roll: check the FAQ section
Postby TRD_ZERO » Thu Sep 28, 2006 10:24 pm
Ok so if i was to purchase a set from toyota the best bet would be to go for the ae101 ones???
SO about those blocks any differences?
TRD_ZERO
Postby bluemaumau » Thu Sep 28, 2006 10:26 pm
if your thinking about a 4agte/ search, comes up every week
