AE101 shocks/springs in AE92
Postby Santa'sBoostinSleigh » Wed Oct 04, 2006 3:23 pm
anyone know if AE101 struts and springs will fit an AE92 FXGT?
is there anyone who has a set of springs lying around that they can measure the diameter of them please?
of if anyone has an old rooted or whatever AE101 front and rear shock (and springs?) that i can have to do some tests on let me know
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby bluemaumau » Wed Oct 04, 2006 4:40 pm
pretty sure the backs fit, 75% sure fronts also
Postby Cakky » Wed Oct 04, 2006 4:53 pm
a bit far fetched but what about ae111 springs to ae92.
my mate has a spare set of super low kings from his ae111 i wouldnt mind trying in my car ( ae92 )
Cakky
Postby AceSniper » Wed Oct 04, 2006 5:00 pm
the seats slightly very in size dosnt matter spring still fits just a matter of using or not using the rubber part on the seat.
Im using TRD shocks that were listed for AE92-AE111 the front incerts went into the factory housing, On the rear im using a TRD housing that was made to fit a ae92 it works just dosnt have a bracket for the ABS wire, they all fit its just a veration of brake line holders and ABS brackets.
AceSniper
Postby Mr Revhead » Wed Oct 04, 2006 5:03 pm
ae101 and ae111 are the same shocks and springs
we are trying to find out if/how ae101/111 shocks and springs fit into an ae92
dont want to hear anything about ppl having the springs side by side and saying they are exactly the same, coz they arnt and the 101/111 springs dont fit the ae92 properly
basicly the aim of this is to see how we can get later model stuff that is still availible to replace parts which are no longer made for the ae92
Postby AceSniper » Wed Oct 04, 2006 5:27 pm
AE101/AE111 springs have a slightly fater base, on a AE92 strut "low" king springs, and Tein AE101/AE111 springs sat tightly in the lip of the shock It woudlnt come out but it didnt fit down flush against the base surface and this is with out the rubber on the seat. but... King super lows listed for a AE111 sat down on the seat astho it was made for it.
so the veriation is very small, fronts I never went into it, this was because the inserts bolted into stock houstings, while the rears are welded up.
as for the struts it all comes down to were the mounts are located for bolting on brake lines and all.
AceSniper
Postby Santa'sBoostinSleigh » Wed Oct 04, 2006 5:28 pm
i do know for a fact that AE111 springs have a larger diameter than AE92 ones, and in turn, the spring housing is larger to accomodate this (this was rears of a BZG)
i put an AE92 spring into the AE111 housing, and it rattled around even with the rubber bit in
Santa's Mega Sale
Postby sergei » Wed Oct 04, 2006 5:31 pm
We successfully swapped a few AE92/AE82 front complete struts with AE101/AE111 the only difference is how brake hose is clamped to the strut (not a major).
Postby Mr Revhead » Wed Oct 04, 2006 8:09 pm
yeah i thought the fronts would swap easy
its the rear i dont know about. in particular if the 101/111 tophats fit or if you have to use the 92 hats, and if so do the 101/111 springs fit the 92 tophats?
Postby AceSniper » Wed Oct 04, 2006 9:15 pm
hmm didnt have a look at the ae92 tophats maybe tomorrow Ill check it out
AceSniper
Postby AE92blktop » Wed Oct 04, 2006 9:47 pm
I have a AE92 which i stuck 101 springs in the front and they fit fine, also had a look at 111 springs they appear slightly shorter than 101 springs, dunno though if super strut makes any difference to the springs.
AE92blktop
Postby 20v_rollaboy » Wed Oct 04, 2006 9:53 pm
I have ae82 front struts with ae101 Jamex springs. They fit fine and do their job. Only problem is on full lock the springs make a click noise which means they dont sit properly I guess. But they are fine otherwise.
20v_rollaboy
Postby Mr Revhead » Wed Oct 04, 2006 10:02 pm
yeah... the fronts work.
its the rears we need to know about now
Postby KinLoud » Wed Oct 04, 2006 10:14 pm
I put GAB shocks from my AE92 fxgt into my AE101 20v Marino.
FRONT - AE101 springs fitted fine onto the AE92 GAB shocks/struts. As mentioned the bracket to hold the brake line is different.
REAR - AE101 springs DON'T fit the AE92 GAB shocks/struts. The base of the spring is too wide for the bottom spring perch. I didn't want to use the AE92 springs because the were softer than the AE101 springs.
I used ST182 rear springs as their base diameter is same as AE92. I used them with about 0.8 of the bottom coil cut off so the car had the same ride height at the rear. I also wanted a higher spring rate at the rear to balance the handling. With the modified ST182 springs the rear went from about 160lb/inch up to 200lb/inch.
NOTE - As far as I can see front and rear AE101 shocks/struts and springs will bolt straight into AE92. Only issue is front brake hose brackets.
Ken
Ham
021 408 863
Postby Santa'sBoostinSleigh » Wed Oct 04, 2006 10:20 pm
front brake hose brackets are currently modified (via a hammer) to accomodate the superstrut calipers that i have fitted ;)
ie hoses didnt reach, so i bashed the bracket with a hammer until it was in the right'ish position
thats what happens when the BroMotorsport division of the BroMotors Co. attacks your car (me!)
Santa's Mega Sale
Postby Caveman » Wed Oct 04, 2006 10:28 pm
Front ae92/ae101 same
Rear ae92 smaller bottom bucket for spring than ae101. Also different tophat, mounts on a different angle to the chassis (only really slight, you could get away with using ae101 top hats in ae92 but I wouldnt recommend).
To fit front ae101 suspension in ae92, front is straight swap, either ae92 or ae101 parts mix n match
to fit rear ae101 in ae92, must use ae101 strut and coil, use ae92 top hat :D
AW11 Track Toy
Formerly known as 1998
Caveman
Postby Santa'sBoostinSleigh » Wed Oct 04, 2006 10:30 pm
1998 wrote:To fit front ae101 suspension in ae92, front is straight swap, either ae92 or ae101 parts mix n match
thankyou! thats the best answer so far :D
Santa's Mega Sale
Postby Mr Revhead » Wed Oct 04, 2006 10:31 pm
yep ok, do ae101/111 springs fit 92 tophats?
Postby Caveman » Wed Oct 04, 2006 10:32 pm
np I was trying for ages to get trd coils for ae92, but had to get ae101 as trd dont make the ae92 coils anymore.
That is what I did to fit them in my car
AW11 Track Toy
Caveman
Postby Mr Revhead » Wed Oct 04, 2006 10:33 pm
ah... so that was YOU! i knew some one had done it.
