0-100kph times
Postby Chickenman » Sun Oct 08, 2006 10:33 am
flygt4 wrote:you're still kind of pissing into the wind tho , front wheel drives arent known to take off very well.
I've cleaned up a few cars off the line in a FWD (numerous legacy/wrx wagons etc Avenir turbo), I launch around 3500-4500 no wheelspin just drive. I do realise they could potentially launch better than me... but they would have to drop the clutch at high rpm and would probably end up picking parts of their gearbox up off the ground. I've only ever been behind at the change to second once... in the wet... against an evo :o
Note that these cars are obviously standard though.. even a slightly modded turbo car should cream a 20v.
After a service though we noticed the rear shocks are really soft and ned to be replaced, dunno if that has anything to do with it?
Baby Jesus
Chickenman
I Am The Walrus!
Postby flygt4 » Sun Oct 08, 2006 12:18 pm
there will be exceptions , but you cant beat physics , you're always gonna be lifting the weight off the front wheels as you try to get away. its exaggerated in higherpowered fwd's.
that said , i reckon i have enough mechanical grip in my car to get away pretty fast even with the wheels spinning, as it still pulls itself up to speed courtesy of an LSD and decent tyres.
i think my best 60ft times at the drags were 2.2sec, on the shittest federal tyres ever made. that was just dropping the clutch into wheelspin and flooring it til it gripped.no finesse at all :lol:
i believe in a fwd you want the rear shocks as stiff as possible to get away cleanly , as it reduces the lift to the rear and keeps the weight over the front wheels as you accelerate, rather than a rwd where soft is better at the back.
i tried a 0-100km earlier today , and i think i spent about 6 seconds in 1st gear with smoke coming off the tyres ,then about 1sec in 2nd gear reaching 100km. i wasnt really trying too hard tho :wink:
flygt4
Postby crnkin » Sun Oct 08, 2006 12:52 pm
deaf_rattle wrote:8.54 this morning.
i reckon there is still plenty to shave off that time.
was on a slight up hill freshly laid seal (1 week ago) and still with stereo in the car.
Using gyrascopic gforce meters up hill gives you false readings, even when your meter is flat, it still reads more g's when your going up a hill, so tells you that you have accelerated faster. So you probly still did more like a 9.5. 20v's are slow, so get a turbo or something :)
deaf_homo "currrently yes"
crnkin
Postby Dell'Orto » Sun Oct 08, 2006 1:58 pm
Yeah if you use a G Tec or similar, you do need a flat piece of road...bumps and rises can dramatically shave time :lol:
Postby deaf_rattle » Sun Oct 08, 2006 7:32 pm
no g sensor was plugged in. so time was measured and speed was measured.
simple equation really..... so time was correct thanks.
And i have a 500hp supra in the works, so 8.54 from my daily isnt too bad.
:wink:
Postby deaf_rattle » Sun Oct 08, 2006 7:37 pm
also, power is decreased when going down hill, while power is increased going up hill when using a g sensor power run.
0-100 is simply that, how many seconds it takes to get to 100kph. no fancy calculations, just timer starts when the cars starts moving.
Postby matt dunn » Sun Oct 08, 2006 7:38 pm
Just been out doing some setup and data logging on the focus,
and according to the data from the motec,
30kmh to 170kmh in about 10 seconds,
( from a rolling start, just picking two points out of the data)
Not a toyota and more than 20 valves, and more fun to drive.
Postby deaf_rattle » Sun Oct 08, 2006 7:40 pm
matt dunn wrote:Just been out doing some setup and data logging on the focus,
damn thats quick. bet that was fun.
did you do a 0-100 time?
Postby matt dunn » Sun Oct 08, 2006 8:31 pm
deaf_rattle wrote:damn thats quick. bet that was fun.
Nah, 0 to 100k times suck as it's a bit hard to get off the line.
Tripple plate clutch, hollenger sequential, and 770nm of flywheel torque at 3000rpm make launches a thing that requires a lot of practise,
and was more setting up the logging etc etc than checking performance.
Postby Al » Sun Oct 08, 2006 8:48 pm
4.59 0-60mph, with passenger and boot full of tools. Fuel light on running Avgas. Turned around and did the same piece of road in opposing direction, 4.8 0-60mph with a bogged launch. Boost gauge didn't read high enough.
Al
Postby UTERUS » Sun Oct 08, 2006 9:26 pm
In my old 20V AE101 i did a 7.5 second 0-60 mph according to the g tech, that was launching at around 3-4000 and flat shifting from first to second.
That was on a flat piece of road.
UTERUS
Postby CAMB01 » Sun Oct 08, 2006 9:42 pm
6.59sec in my GZE FX :lol:
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby deaf_rattle » Sun Oct 08, 2006 9:47 pm
CAMB01 wrote:6.59sec in my GZE FX :lol:
nice time, what was that measured with?
anytime i set now with the fxgt will quickly get wiped with the other car when its done :lol:
Postby Lith » Mon Oct 09, 2006 9:59 am
I did a low 8s 0-60mph with my old AE82 Liftback with a GTech :D
My old VTEC Prelude used to do ~6.1s 0-60mph, my Skyline does 5.0 all day every day - and occasionally busts out a 4.8 or 4.9 if I manage to keep it straight (glares at Al with his MR traction haha). Thats only on 10psi with filter and exhaust - should be able to go quite a lot quicker next time I do it.
Lith
Postby SkylineObsession » Mon Oct 09, 2006 1:56 pm
I launched my car at about 2,700rpm so wonder if i could have gotten a quicker time than i did (6.35) while revving higher and with only me in the car. :?
I really don't like automatic transmission.
SkylineObsession
Postby Lith » Mon Oct 09, 2006 2:43 pm
Prelude and Skyline were both ~2500-3000rpm launches (manual though). AE82 had to make do with 3500-4000rpm with a mixture of clutch slip and throttle feathering to get the thing moving just to nasty single spinnerness mixed with complete lack of torque :(
Some cars you just seem to be able to give a bunch of revs and let them go - the old Domani (1.6 SOHC non-VTEC) I used to blat around in managed a sub-8s 60mph time, giving it around 4000rpm clutch slip/dump. It would just chirp the fronts and take off in a ball of the biggest fury you dare imagine. Then you slam 2nd, as though you're going to have to hang on for dare life - then nothing much really happened. You'd just wait around for 100kph to eventually easy on by haha.
Lith
Postby beeker » Mon Oct 09, 2006 7:20 pm
Lith wrote:Prelude and Skyline were both ~2500-3000rpm launches (manual though). AE82 had to make do with 3500-4000rpm with a mixture of clutch slip and throttle feathering to get the thing moving just to nasty single spinnerness mixed with complete lack of torque :(
To get 4.8s from i audi needs a straight 5k drop. The word "wiplash" comes to mind.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby Lith » Tue Oct 10, 2006 8:50 am
Ooooo yeah I can imagine the RS4 being a hoot to launch haha
Lith
Postby Chickenman » Tue Oct 10, 2006 9:53 am
My old corona did 9.8-10 with me and a 100 kilo timer person :o Tried a couple of times... not so accurate of course. My favourite was the 160-0 brake test, we never timed it though. Braking is where it's at for "make your passengers anus quiver" kinda fun.
Baby Jesus
Chickenman
I Am The Walrus!
Postby Bling » Tue Oct 10, 2006 10:35 am
Chickenman wrote:Braking is where it's at for "make your passengers anus quiver" kinda fun.
its also great for when that said person is annoying the f**k out of ya!!!
Not sure i'd try it from 160 tho!!! i'd be worried about going sideways off the road :lol:
