DamDistrb wrote:punter - Sounds like a rattle from the big end bearings. Other than new bearings or bottom end rebuild, maybe swap out for another good known bottom end?
Punter wrote:DamAny way to be sure?
So I guess I'll replace the bearing then
Pelo wrote:My 4age has been doing the same thing just recently, will have a coarse rattle for maybe 1-2 seconds on startup and then it goes away completely. Does it more often when cold, less so when hot, and sometimes will not do it at all regardless of temperature. Maybe oil pump draining between runs? Got me worried too
quicklvn - goes away when driving? if so then sounds like vvt pulley rattle.
Yeh, I think it must be that then. It's only at idle and when under acceleration it goes away. Does this have any effect on power etc?
Mr Revhead wrote:yeah i can do genuines for some where around $190-200 iirc
acl are ok for a street driven runner.
Punter wrote:Mr Revhead wrote:yeah i can do genuines for some where around $190-200 iirc
I try to do 4-5 trackdays per year, are ACL still good enough?
hmmm, you can buy replacement engine thats guaranteed for that sort of money. So maybe I should just put $500 away and wait to see what happens.
1998 wrote:If you want to do bottom end, big end bearings are $50 a set, main end are $50 a set and thrust are about $20. These are ACL and are avaliable from partmaster. The genuine toyota is $50 per bearing so $250 for a set. I have been to ACL office and had a lot chat with the guy, they seem pretty good, the only thing they dont have is manufacturing clearences. Bascially for them one bearing fits all. The are copper lead and dont require any run in time.
