Suspension Query
Suspension Query
Postby TOYROTA » Tue Oct 10, 2006 8:55 am
Hey guys im just curious as to what parts i would need to change to make some AE86 coilovers fit into my KP starlet and also do any of you have the necessary parts to do the changeover that you would be willing to sell?
Any help or advice on this subject would be appreciated as its starting to mess with my mind.
thanks
Curre3nt rides-
1982 starlet kp61 4 door (in panel shop getting bare metal resto)
1980 tt132 corona wagon 3t t40 (daily doomsday machine)
TOYROTA
Postby Bling » Tue Oct 10, 2006 10:38 am
I cant help in anyway :oops:
however from what the auction says, you might need these
http://www.trademe.co.nz/Trade-Me-Motor ... 710207.htm
someone else on here will confirm
Postby Jebus » Tue Oct 10, 2006 10:44 am
Yep, if you use them, youll need AE85/6 Steering Arms and brakes. But you can still use your stock lower arms with stock balljoints.
AE86 coilovers with AE85 steering arms and brakes will be relatively cost effective, good suspension, slightly bigger brakes. Win Win.
Jebus
awesome
Postby TOYROTA » Tue Oct 10, 2006 10:53 am
thanks guys, i should still be able to run evo discs and sw20 2pots tho aye? also any more info would be a great help as i wanna try get it rite the first time as this is my daily driver and wanna minimise the time off the road.
Curre3nt rides-
TOYROTA
Postby Jebus » Tue Oct 10, 2006 10:57 am
Yep, you should still be able to use the MR2 2 Pots, id go with Nissan Bluebird or similar Rotors over the Evo Discs, just need a different shape adaptor plate.
Next question, WTF is your daily packing that you want 2 Pots? If its just a stock 4age or similar you will be fine with rebuilt AE85 brakes with good pads and fluid.
Aside from being excessively overkill, it really limits your selection of wheels, I hate not being able to fit small wheels over my brakes :(
Jebus
good point
Postby TOYROTA » Tue Oct 10, 2006 12:25 pm
very good point bout the wheel selection, i hadnt thought bout that issue and as im retaining my 14" celica rims the evo discs are a no go. what model bluebird and are they vented discs?? its only packing a 4k so i know its overkill however im gunna start goin on the track as much as possable so i know my solid kp discs and callipers wont cut it
Curre3nt rides-
TOYROTA
Postby Dell'Orto » Tue Oct 10, 2006 12:42 pm
You'd be surprised, with new pads and brake fluid, and as long as they're in good shape, your stock brakes will work fine on the track. Its not like the car is heavy or powerful.
YEP A 4K
Postby TOYROTA » Tue Oct 10, 2006 1:32 pm
yep its just a 4k and they arent needed however i would like the bigger brakes so when i do decide to get a moter that has lots of horses inside it then i wont have to worry bout doin the upgrade.
so which components do i have to replace in order to fit ae85/86 coilovers??
lower arm?
balljoint?
tierod and rackend?
Curre3nt rides-
TOYROTA
Postby Jebus » Tue Oct 10, 2006 9:05 pm
You need that bush in the link above, AE85 steering arms, tie rods, lower arms etc will be fine.
Jebus
Users browsing this forum: Google [Bot] and 24 guests
