BZG|Bling wrote:if i understand correct..... can u not just sit the led in the hole the tracks lead to and no touch the dash cluster? could be must less hassle
Quint wrote:Better yet, put a switch on 5th so when u change to 5th an OD light comes on :O
You could also rig up a pressure sensor so when you hit a vac of ~14"mg a eco light comes on, that'd be cool, Could have a light for when u press the acclerator, OMG u could have lights for when ur suspension travelled too!
phat_levin wrote:
you c***. maybe they should put a light on the posts so that wen some dickhead puts a smartass post up the light flashes
Now i'm upset
Seriously, It'll piss you off though, I have two cosntantly flashing at me, a turbo light and a OD light blinks non stop (missing part of the auto loom) Personally though if i was going to do what u want to do i'd try to do it completely independantly of the facorty circuits, cause all that dash cluster wiring is pretty damn complex and u don't want it messing out.
If they had a flashing light on smartass posts toyspeed would light up like a christmas tree
Users browsing this forum: Bing [Bot] and 20 guests
