Stereo Short Circuted **FIXED THANKS TO T.S**
Postby BZG_UNIT » Sat Oct 14, 2006 10:32 pm
Hey guys. My bro attempted to put a new head unit in an EP82 starlet NA. And he didnt earth it properly and has fried the wires. THe plastic on the wires going to the headunit started to smoke and we quickly disconnected it.
THese are the after effects:
-No power going to headunit
-Inside lights (on the roof) dont work
-Clock doesnt go. only when lights are on.
-Car doesnt beep when lights are left on or key is in ignition and door is opened.
Anyone know where the fault is likely to be? Ive check all fuses so not a fuse problem.
With your help i aim to repair all faults :) ... If that fails off to the auto electricitions
Thanks in advance :)
1997 Toyota Trueno
1990 Toyota Trueno GTZ
BZG_UNIT
Postby flat_0ut » Sat Oct 14, 2006 10:35 pm
I'm 99% sure it will be a fuse somewhere. It's happened to me before :oops: (not on my car thankfully)
flat_0ut
Postby RickGT » Sat Oct 14, 2006 10:36 pm
has to be a fuse, theres usually a little fuse at the back of the headunit, what wire was smoking? the + or ground?
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Re: Stereo Short Circuted
Postby Chickenman » Sat Oct 14, 2006 10:41 pm
BZG_UNIT wrote:-Clock doesnt go. only when lights are on.
He's possibly wired it up with the negative on the light wire (used in older stereos). Got test light? they always see the light circuit as an earth cos the filament conducts electricity back to ground... then you turn on the lights and...
Baby Jesus
Chickenman
I Am The Walrus!
Postby RickGT » Sat Oct 14, 2006 10:43 pm
i see, i always go straight to the body (if you can that is) heaps easier an that way you know its ground
EP91 Glanza V
RickGT
Postby BZG_UNIT » Sat Oct 14, 2006 10:47 pm
most the wires got fried. The plastic melted off them in places. Ive checked all fuses. Plus one in the head unit. Could it possibly be a fault in behind the dash somewhere? due to the short circuting?
1997 Toyota Trueno
BZG_UNIT
Postby Chickenman » Sat Oct 14, 2006 10:57 pm
Dude.
Don't let your brother touch your car again.
May have to take it to a sparky dude, if you aint sure you'll probably only make it worserseser.
Baby Jesus
Chickenman
I Am The Walrus!
Postby BZG_UNIT » Sat Oct 14, 2006 11:20 pm
its the mrs's car. He did my sounds all good. Maybe cause mines a ae111 and its gifted.. lol. Yeh may have to take it to the men. lol.
thanks guys.
more info would be helpful too :)
1997 Toyota Trueno
BZG_UNIT
Postby Mr.Phreak » Sat Oct 14, 2006 11:24 pm
Sounds very much like the Dome fuse under the bonnet has gone.
Mr.Phreak
Postby BZG_UNIT » Sat Oct 14, 2006 11:59 pm
dome fuse? i only really looked at the ones under the steering wheel
.. ill check the dome fuse out tomorrow :) thanks..
If that fails .. what else?
1997 Toyota Trueno
BZG_UNIT
Postby eritate » Sun Oct 15, 2006 12:41 am
Give logan a beating... Talk to andy, See if he has enough time to have a quick look for ya ( beers go down well for payment - export dry)
Haha
GL calvin
Mike
I am a timewaster. Ignore anything I say
eritate
Postby Lloyd » Sun Oct 15, 2006 8:13 am
Check more fuses. The symptoms all point to dome fuse
Postby samlloyd » Sun Oct 15, 2006 11:08 am
Second the dome fuse motion, Sometimes they are just called ACC fuse
Karl Pilkington On seals - "Its between a fish and a dog."
samlloyd
Postby BZG_UNIT » Sun Oct 15, 2006 4:47 pm
eritate wrote:Give logan a beating...
Haha yeah. He did mine ok and his. then it comes to emmas car and shit hits the fan... lol
Thanks guys ill check the dome fuse? and other ideas if its not that ???
1997 Toyota Trueno
BZG_UNIT
Postby Mr.Phreak » Sun Oct 15, 2006 5:14 pm
If it's not that, I hope you're feeling rich
Mr.Phreak
Postby BZG_UNIT » Sun Oct 15, 2006 5:45 pm
Mr.Phreak wrote:If it's not that, I hope you're feeling rich
Haha either that or she can put up with half the electrics not going hehe
1997 Toyota Trueno
BZG_UNIT
Postby CozmoNz » Sun Oct 15, 2006 6:07 pm
its really not that hard to just completely re wire the headunit...
just find all the sources again and run new wire to the speakers (if you want / need to), not hard.
and yeh, second the motion to never let ur brother touch anyones car again.
Rayne For President!
CozmoNz
Postby BZG_UNIT » Sun Oct 15, 2006 9:07 pm
Thanks guys for all your help. Fortunately i fixed the problem!! and the mrs's was stoked
It ended up being a fuse.. was all in jap so i checked all the fuses and a 15 was fried to bits.
THANKS GUYS REALLY APPRECIATE YOUR HELP!! thank god people here know there shit 8) 8)
1997 Toyota Trueno
BZG_UNIT
