THese are the after effects:
-No power going to headunit
-Inside lights (on the roof) dont work
-Clock doesnt go. only when lights are on.
-Car doesnt beep when lights are left on or key is in ignition and door is opened.
Anyone know where the fault is likely to be? Ive check all fuses so not a fuse problem.
With your help i aim to repair all faults
Thanks in advance
