cogent wrote:iPhones can eat a dick.
Mr Revhead wrote:google appears to be saying 13b NON turbo weights 146ish kg assembled as it would be in a car.
Skin wrote:well i lifted it into the boot of a corona by myself![]()
And manifolds and turbos dont weigh that much aye, i would guess my setup would be 15kg at the most
crnkin wrote:Mr Revhead wrote:google appears to be saying 13b NON turbo weights 146ish kg assembled as it would be in a car.
sweet i was 1 kg off.
Ground type scales actually wont be acurate to weigh things anyways. I semi understand pretty well how they work, and no matter how much you try to position something on a set of scales theyll always be out, more so on something like an engine, as they are very dense, so wont spread to all load cells.
Best way is to hang it off a set of hanging scales with a spring weight, then its heaps more accurate.
And yes, 85kg= not that heavy. I can lift a 4agze out of my car over the xmember by myself, and im not exacly team (dan the big bear), and theyre well over 100kg with 5kg of oil, 3kg of water etc. (admittedly strugling but hey i only weigh 68kg's) (lies, im 78 at the moment)
Rotorys are farken heavy, dont get that wrong. Go the 1uz!
Mmm, Boost wrote:Estimate all you want, when I had an NA 13B delivered to my house on a pallet, the weight was 112kg. Thats a complete motor, flywheel to fan with oil. Pallet wouldnt weigh a hell of a lot, maybe 10kg tops?
Mr Revhead wrote:not many if any freight companys accurately weigh private items![]()
and belive it or not, i have actually lifted more than a couple of rotarys. and they are NOT light. compact, yes. but not as light as most believe.
AE85coupe wrote:4age
because it will so so god dam easy to do
good to roar round in till you save some cash and get your suspension and driveline sorted for the big power
