True-No-Turbo wrote:tgb.mr2 wrote:I liked your car ^ quite niice. Think you should put your gear in my car though
thanks mate, lol by the looks of it I think you may need to invest in some rear tyres first haha
~SlideWays~ wrote:Hey True-No_Turbo, I thought I read that your turbo had given up? Whats the story?
flygt4 wrote:kind of , boost still fluctuates rapidly but only from low rpm in 4th and above 17psi. it actually improved when i increased the idol seat pressure on the BOV.
I do have an un4agte related irritation ,a sticky starter motor that wont disengage momentarily after start , of which ive already replaced the starter motor/solenoid&ignition switch.
it actually was fine for a while with the new starer motor, and is slowly just starting to stick again. i need to have a lil think about it, coz i dont believe in coincidences.![]()
its a right bastard as i need to remove the inlet manifiold to get to it,and clear room in the engine bay so i can stand between the gearbox and radiator.
~SlideWays~ wrote:True-No-Turbo wrote:tgb.mr2 wrote:I liked your car ^ quite niice. Think you should put your gear in my car though
Just wondering cause Im thinking of maybe using one of those unbranded t3/4 since my gt28 looks to be $&#$%.... but still waiting for confirmation.
tgb.mr2 wrote: it seems i have gotten a hold of an sc14 too.
boost boost
True-No-Turbo wrote:tgb.mr2 wrote: it seems i have gotten a hold of an sc14 too.
boost boost
Matt (xsvwgn) is looking at doing a sc14 conversion also. Ive always wondered what it would be like with an sc14, must have heaps of boost off idle, would be nuts!
Nobody seems to finish the conversion or they all seem to have problems. I may look at doing it to my Levin a bit down the track but first things first.
flygt4 wrote:ran into a guy one night who claimed he spent up to 3500 paying someone to do an sc14 conversion and still didnt have it going properly.
bOi wrote:hey guys, excuse me if this has been asked but i cant seem to find itand i hope its alrite to ask in this thread, did not wan to start a new one. Im planning a 4agte build with a blacktop on standard internals with about 5-8psi (may upgrade in the future with forged internals etc)
1) Is it safe with 11:1 compression? I know its been done here on silvertops with 10.5
2) If i was to use a GZE bottomend with the 20v head, can I still use my gbox from the 4age? C160
3) What ecu should I use? GZE be ok or go for a link?
4) tdo5h (evo) or t3/t4 (T04E) ?
5) If I was to use my bottom end, is the BT rods sufficient? or should i change to ST rods?
Ok, I hope I didnt offend anyone if these were asked before cuz i have read too many threads and cant find any answers.
Thanks
boost boost
slighty_sykotic wrote:Hey guys,
Time for 4agte build number 3![]()
Just sold my blacktop 20v to make way for this.
rebuilt 20v silvertop with 4agze pistons (8.9:1)
blacktop throttle bodies
t3/t4 turbo (big one... not compleltly sure on specs, Im trusting Bazda)
injectors (havn't got these yet... need some 3sgte ones)
custom manifold and intake plenum
38mm wastegate (probably just a ripoff, i sold my tial)
50mm BOV (modified rip off one)
New G3 link LEM and LC1 wide band oxygen sensor setup.
Aiming for 200kw at the wheels, at about 20psi.
oh yeah, and its going into a AW11
