Dave, switch back to eliminate the possibility of something magically fixing itself!
If it turns to crap again, you know its the gas, if it doesn't... Then maybe there really is a Hogwarts!
Mr Revhead wrote:
as far as 98 goes i used mobil as thats all thats avail close to home. never noticed a diference when i have run bp though
flygt4 wrote:our wagon has the factory jap fuel economy/av. speed lcd screen.
there is a clear difference of approx 2km/L between 95 and 98
RH9 wrote:Ultimate in the UK is now 100 octane - was re-released earlier this year in a new formula.
TTEETT wrote:Ran my old car (Supercharged Altezza) on the Dyno with both Mobil and BP 98 and found no real power difference, but the car ran a lot better and showed higher lean out thresholds using BP Ultimate, go figure.
Plus Mobil 98 is pink and pink is for girls.
Lith wrote:TTEETT wrote:Ran my old car (Supercharged Altezza) on the Dyno with both Mobil and BP 98 and found no real power difference, but the car ran a lot better and showed higher lean out thresholds using BP Ultimate, go figure.
Random. I always thought it was purple... maybe I am colourblind. That would explain a lot of things.
TTEETT wrote:Lith wrote:TTEETT wrote:Ran my old car (Supercharged Altezza) on the Dyno with both Mobil and BP 98 and found no real power difference, but the car ran a lot better and showed higher lean out thresholds using BP Ultimate, go figure.
No your not colourblind, the colour of the gas itself is pink, the pump handle is purple (international Colour of the Homosexual).
