Leaky Corona
Leaky Corona
Postby toyrota mota » Tue Nov 07, 2006 11:54 am
Just wonder if any of you other old toyota owners has had this problem before. After it rains my corona gets a very damp(depending on how hard the rain is) passenger foot well and only the foot well, it doesnt feel damp up towards the dash :? . Has this happen to anyone else, how do i fix it, whats it most likely to be and if not whats the best way to find where the leak is?
Campbell
toyrota mota
Postby Mr Revhead » Tue Nov 07, 2006 12:31 pm
what model?
could be rust. or block drain holes in the cowling and itll be dripping through the heater vents
Postby toyrota mota » Tue Nov 07, 2006 4:48 pm
Its a 79 TT132 wagon. Cowling? Is that the part at the bottom of the windscreen, that collects water?
toyrota mota
Postby z|gen » Tue Nov 07, 2006 6:41 pm
i got the same problem in my rona too,
once i get under there in the weekend, il let you know if i figure out lol,
maybe remove passenger guard and see if you can see any problems?
AE91 SUPERCHARGED COROLLA
z|gen
Postby cr1mnl » Tue Nov 07, 2006 7:26 pm
my gf's old levin had a similar problem, drain holes in the boot had blocked up and spare wheel well was full with water. braking caused water to slosh forward under carpet and into the floorpan. took a while to find out where it was coming from lol
http://toyspeed.blakjak.net/profiles/profile.php?id=708
Horsepowers for bragging, Torques for dragging...
www.ology.co.nz
cr1mnl
Postby toyrota mota » Tue Nov 07, 2006 9:47 pm
cr1mnl wrote:my gf's old levin had a similar problem, drain holes in the boot had blocked up and spare wheel well was full with water. braking caused water to slosh forward under carpet and into the floorpan. took a while to find out where it was coming from lol
Don't think this is my problem as mines a wagon, no wheel well and no drain holes in boot(well does'nt have a boot like that).
So my best bet would be to take the cowling(the peice below windscreen) off and check for rust holes or blocked drain holes here????
toyrota mota
Postby fangsport » Tue Nov 07, 2006 10:15 pm
toyrota mota wrote:So my best bet would be to take the cowling(the peice below windscreen) off and check for rust holes or blocked drain holes here????
yip, then check to see if it is leaking around the screen seal due to rust.
fangsport
