Silvertop Fan Allways on???
Postby 4-AGE 4-LIFE » Tue Nov 07, 2006 3:28 pm
Hello
ive got a 4age silvertop in my ae101
each morning i start it up the fan is running and still is when the car is at normal running temperature, the cold idle works fine idles at about 1500
then when its warm idles at about 800
ive replaced the temp sensor to the ecu
and the fan switch sensor
does anyone have any ideas why this could be happening???
Ben Threadwell
Exsus Automotive
Suspension specialists
4-AGE 4-LIFE
Postby sergei » Tue Nov 07, 2006 3:48 pm
you have to short wires going to A/C pressure sensor. The plug for it has 4 wires you have to short on of 2 opposite pairs. The plug is located next to left front strut.
Postby 4-AGE 4-LIFE » Wed Nov 08, 2006 1:33 pm
sorry i dont know where your talking about
are you talking about the fan relay in the fuse box under the bonnet
Ben Threadwell
Exsus Automotive
4-AGE 4-LIFE
Postby sergei » Wed Nov 08, 2006 2:07 pm
there should be plug hanging off loom close to ignitor, but not connected to anything. (it is usally connected to pressure switch on the aircon line).
Postby 4-AGE 4-LIFE » Wed Nov 08, 2006 3:13 pm
thanks for that mate, much appreciated.
i found it at smoko and noticed the plug wasnt plugged in :oops:
now its all working fine
Ben Threadwell
Exsus Automotive
4-AGE 4-LIFE
Postby deaf_rattle » Wed Nov 08, 2006 5:20 pm
what colour are the wires?
Postby sergei » Wed Nov 08, 2006 5:21 pm
from memory green-something ???
Postby deaf_rattle » Wed Nov 08, 2006 5:28 pm
true.
does this wire go back to the ecu? i think the a/c wiring has been trimmed out of my loom
Postby sergei » Wed Nov 08, 2006 6:53 pm
as far I I am aware it is not switch by ecu, but it should conect to electric load sense pin on ECU.
