Help Ive broken something!!! :lol:
Postby Roydon » Fri Nov 10, 2006 9:47 am
Ok yesterday afternoon after a bit of spirited driving i broke something!! Now this is my 1st 4agze and since i didnt built the motor i not really to sure what ive done. Im pretty sure ive only rooted the SC12??.
This is what happened leading up to the turn of events. I was coming thru a series of S bends and was sitting pretty high in 3rd, Just got into the straight away, hesitated for maybe a couple milliseconds changing up and then a evil shreeching sound came out from in front of me. I put the car in neutral, gave a few blips on the gas and the screeching noise was still there. I pulled over and left the car running, the car then procedded to to rev its nuts of by itself then itd back off then rev again and back off and so on so on. I checked the accelerator cable wasnt jammed and then turned the car off. I proceeded to check all the belts and they looked fine the belt coming from the SC12 is still there so i didnt break it, Im thinking maybe ive killed the clutch?? the car runs but it isnt driveable as it proceeds to rev by itself. Also it isnt leaking any oil if that helps
Any help in diagnosing my problem would be great, and also any other possible faults!!
Cheers Roydon
"Its hard enough trying to remember my opinions without trying to remember my reasons for them"
Roydon
Postby bluemaumau » Fri Nov 10, 2006 10:56 am
what sort of revs is it sitting at?
i know when i cleaned my engine the throttle was covered in oily grease, maybe might need a clean
Postby Roydon » Fri Nov 10, 2006 11:10 am
its pretty much going from idle to redline repeatedly (dont have a tacho on it at the mo). Howe would the grease or oil got on to it?? would that also cause the screeching sound when i touch the gas?
Roydon
Postby bluemaumau » Fri Nov 10, 2006 11:14 am
no the throttle might have been jamming, mine wa sticky as!
it wont be the only problem if its oily tho. check your tps
mates integra was doin the same thing then we realised the tps was bung :lol: o well its a honda
Postby Roydon » Fri Nov 10, 2006 11:19 am
Sweet will look at it after!!! damn it was going so good too 8)
Roydon
Postby Roydon » Fri Nov 10, 2006 4:10 pm
Sorry it wasnt this. Any other ideas!!!
Roydon
Postby ~SlideWays~ » Fri Nov 10, 2006 4:26 pm
Could have been the sc belt slipping...or any belt. Dunno about the reving though, could be an air leak?
~SlideWays~
Postby MR2SIK » Fri Nov 10, 2006 6:13 pm
At a track day in Timaru last year there was a ae8* with a 4agze conversion, It got trailored back cos it was constantly revving high, iirc it was due to the intake pipe coming apart after the throttle body, with no throttle controlling air flow it was just bouncing off the limiter.
My brothers levin also has a miniscule leak in the intake, causing it to whistle/squeal/squeak at high revs.
Maybe you got a problem in between these two issues?
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby evil_si » Fri Nov 10, 2006 6:26 pm
check your intercooler hoses,
it will rev uncontrolably if youve split or blown one off.
check over all the hoses, anything on the engine side of throttle body, theres also a hose underneath the supercharger, pita to get to.
as for the screech its probably the supercharger, you can unplug it and run on the bypass, but its gutless, run it like this and it will tell u if its the blower or not by weather it still screeches
evil_si
Postby shazeal » Fri Nov 10, 2006 7:45 pm
I replaced the intercooler joiners on my gze a few days after buying it, they were totally rooted, big cracks and stuff. If the joiners have a bulge in the middle of them they are the factory ones, just grab some decent silicone intake hose 2" stuff.
But yea id try turning off the S/C completely first as evil_si said, could be dead, is a couple going on Trademe atm tho if your unlucky and it is dead.
Current - 83 Levin AE85 Notch.
Ex - 89 Sprinter - Red Top, 88 Levin - 4agze.
shazeal
Postby bluemaumau » Fri Nov 10, 2006 8:03 pm
how much psi are you running?
Postby evil_si » Fri Nov 10, 2006 9:34 pm
first thing to do if its reving uncontrollably is check the intake system, there will be a leak there somewere, find that and fix first then look at the s/c it could be a boost leak thats making the noise.
evil_si
Postby TTEETT » Sat Nov 11, 2006 9:10 am
Is the supercharger speed controlled by an auxiliary throttle cable, if so check that, had that same sound on my Altezza once.
Just a thought.
TTEETT
Postby evil_si » Sat Nov 11, 2006 9:14 am
TTEETT wrote:Is the supercharger speed controlled by an auxiliary throttle cable, if so check that, had that same sound on my Altezza once.
Just a thought.
nope, they have an electro magnetic clutch system.
controlled by the ecu, dependant on rpm and throttle percentage
evil_si
Postby Roydon » Sat Nov 11, 2006 10:09 am
Thanks guys will let you's know how i get on!! Im glad some people have heard or experienced similar things!!! 8)
Roydon
