Is this safe?
Is this safe?
Postby mr2--mad » Sat Nov 11, 2006 9:37 am
I a second hand afm off ----- and a new kn pod filter but didnt replace the o2 sensor (350+gst) like robin recommended .What do you guys rekon is it about average for a standard sw20 3sgte?
mr2--mad
Postby 4000GT » Sat Nov 11, 2006 9:50 am
Dont know if its normal for the motor, but its bloody rich across the entire map.
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Postby Tukumi » Sat Nov 11, 2006 10:01 am
Pretty standard fuel ratios for that car, like alot of factory stuff pretty rich on boost. Good power for the boost your running.
AE85 4AGTE, 11.9@115mph <--Watch this space 229kw at the wheels ***sold***
WWW.NZEFI.COM
WWW.DORIMONS.COM
Tukumi
Postby Akane » Sat Nov 11, 2006 12:17 pm
Above average power imo for a standard MR2, I clocked in at 122rwkw but that was 6 years ago, with their older software. Standard off the yard.
Your car's fine and the AFM's fine. I don't sell dud crap. Unlike a certain person by the name of Looxxie
Postby mr2--mad » Sat Nov 11, 2006 12:37 pm
That dyno is up 18kw since installing your afm bro :D no black skid mark after start up either I got a great deal off Akane :D
Im just wondering if my o2 sensor or something else(not the afm i know thats working) is all sweet because its so rich. I figure if I up the boost it wont run so rich ??????,theres a tap next to the turbo I dont know which ways up but I might as well turn it and see what happens
mr2--mad
Postby Dell'Orto » Sat Nov 11, 2006 2:10 pm
Its just stock fuelling being very cautious, they all seem to run pretty rich.
Yeah winding up the boost will lean it out, dont go over 12psi without disabling the fuel cut ;)
Postby mr2--mad » Sat Nov 11, 2006 2:32 pm
I havent got a ebc,but there is a tap next to the turbo(so i dont know what i would turn it up to)What about getting the right spring rate spring for the actuator 12psi is that an option?, Theres also an air tube with a screw blocking it under the drivers seat(i guess it used to go to the factory boost gauge) that tees off the boost pressure sensor line which is still connected to the inlet manifold ,should I dissconect that an block it up?
PS i dont want to over 12 but 8 seems pretty lame
mr2--mad
Postby mr2--mad » Sat Nov 11, 2006 2:49 pm
Ahh, but if I turn the tap and it makes the turbo boost 20psi(could be any number) and the fuel cut isnt disarmed then I would blow my motor ..again ,Is this right ?High boost no fuel =bang
mr2--mad
Postby Dell'Orto » Sat Nov 11, 2006 2:53 pm
Can you get a picture of the tap? Does the factory boost gauge on the dash not work?
If the boost cut is still working, then you wont be able to hit 20psi, it'll cut at 12.5psi.
Postby mr2--mad » Sat Nov 11, 2006 3:00 pm
well it never moved before I broke the speedo needle but after I got that fixed at the speedo shop It actually does go up and down (sometimes) its an electric speedo not cable. I never hooked a air pipe up to back of the speedo cluster unit, positive of that , would the dash boost gauge work off electric wire or vaacum pressure .pic coming
mr2--mad
Postby MR2SIK » Sat Nov 11, 2006 3:02 pm
Mmm, Boost wrote:Its just stock fuelling being very cautious, they all seem to run pretty rich.
They seem to run rich no matter how much boost you put through (within reason of course) My AFR was pretty much identical to mr2- mads one at nearly 18psi
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby mr2--mad » Sat Nov 11, 2006 3:08 pm
The tap was in this position for that dyno run
mr2--mad
Postby MR2SIK » Sat Nov 11, 2006 3:14 pm
is that little filter coming off the bov? thats probably why its running stupidly rich on such low boost? GEt it plumbed back into the intake, will make a heap of difference.
MR2SIK
Postby mr2--mad » Sat Nov 11, 2006 3:18 pm
na thats the rocker cover breather
mr2--mad
Postby MR2SIK » Sat Nov 11, 2006 3:27 pm
ah I see.
The bov venting to atmosphere wont be helping the air/fuel ratio, Ask Mr Monkey on here about the difference once he got rid of his aftermarket bov and went back to plumb back.
when I vented my stock one it just belched black smoke constantly, and the flames from the exhaust that you could see from the rear view mirrors showed just how much fuel was being wasted haha :twisted:
MR2SIK
Postby mr2--mad » Sat Nov 11, 2006 3:32 pm
Can I turn the tap with out worrying about blowing up my motor?, due to fuel cut ,I thought about going back to stock BOV (way better)but i decided i like blowing off, it feels so good
mr2--mad
Postby Dell'Orto » Sat Nov 11, 2006 3:34 pm
mr2--mad wrote:but i decided i like blowing off, it feels so good
:lol: :lol: :lol: :lol: :lol: :lol: :lol:
In fact...
Postby mr2--mad » Sat Nov 11, 2006 3:35 pm
I guess that is my problem though I should go back to stock BOV it would be alot better cheers Buddy :wink:
mr2--mad
Postby MR2SIK » Sat Nov 11, 2006 3:39 pm
i got no idea on the cost of it, but that new one from GFB looks good, is adjustable from within the cabin can go from full noise to full plumbback or in between,
MR2SIK
Postby mr2--mad » Sat Nov 11, 2006 3:48 pm
What about just gettin my one plumed back to the intake, is that possibly?
mr2--mad
