20v silvertop misfire
Postby ~SlideWays~ » Thu Nov 16, 2006 11:55 am
On very light throttle the car will always jerk when you take your foot off and also sometime when accelerating on 1/5 throttle (like bunny hoping). There is no problem with full throttle or even half throttle. No misfire on hard acceleration.
I've tried:
- 2 different sets of plug leads/coil lead which I know are good.
- New set of plugs
- Tried coil and ignitor from Blacktop which runs fine
Haven't tried fuel filter or TPS.
Has anyone else had this problem?
~SlideWays~
Postby Mr Revhead » Thu Nov 16, 2006 12:28 pm
yes.
run it on 98 octane, or retard timing 2 degrees, clean oil residue from intake
run catch can, check TPS
then blame nz fuel when you cant fix it.
im guessing it only happens when cold and goes away when warmed up?
Postby ~SlideWays~ » Fri Nov 17, 2006 8:47 am
Mr Revhead wrote:yes.
I put 98 in it right before driving it home from palmy :lol: (no difference)
Then found that the thermostat was stuffed and was running dead cold at 100km, have put a new one in now and still no difference. (haven't checked economy though... hopefully improved)
Will have to check timing and TPS and go from there...stoopid toyota's are so crap :lol:
~SlideWays~
Postby Mr Revhead » Fri Nov 17, 2006 9:13 am
so it does it when its hot?
Postby ~SlideWays~ » Fri Nov 17, 2006 9:39 am
Mr Revhead wrote:so it does it when its hot?
Indeedy it does. Well the gf says it does, will have to try it myself though.
You reckon its a temperature thing?
~SlideWays~
Postby Mr Revhead » Fri Nov 17, 2006 9:48 am
dont know, iv only ever heard of it when cold or half warm
mine did it quit ebad at times when half warm, but never when hot
Postby ~SlideWays~ » Fri Nov 17, 2006 9:58 am
Mr Revhead wrote:dont know, iv only ever heard of it when cold or half warm
Hmm interesting, will definitely do some testing this weekend 8)
~SlideWays~
Postby rolla_fxgt » Fri Nov 17, 2006 11:02 am
mine did a similar thing & it was the o2 sensor being faulty, being a poor student & not liking the price for a new one i just got mine cleaned & reset. It was fine for a few years, but its just started doing it again.
Its quite offputting really.
I thought mine was the tps too, so did the toyota mechanics here (dunedin), but it wouldnt throw up the fault code so thats when we looked for other things
rolla_fxgt
Postby Loudtoy » Fri Nov 17, 2006 4:51 pm
My old one did something similar to that, checked everything then had the intake off one day and noticed that the afm seemed to be slightly open, turned out there was a bit of something in there causing it to be a bit stiff, cleaned it out with some petrol and the flap came free, ran heaps better after that no miss better fuel economy and more power :)
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby ~SlideWays~ » Fri Nov 17, 2006 4:54 pm
Loudtoy wrote:My old one did something similar to that, checked everything then had the intake off one day and noticed that the afm seemed to be slightly open, turned out there was a bit of something in there causing it to be a bit stiff, cleaned it out with some petrol and the flap came free, ran heaps better after that no miss better fuel economy and more power :)
Will have to give it a good clean then!
~SlideWays~
