4afe performance,or lack of.
Postby rolla wagn! » Tue Nov 14, 2006 6:18 pm
any ideas to make extra power out of a 4afe,iv already got a pod filter,and was told upgraded plugs and leads wouldnt help at all,is this true,lookin for long term power,ie not octane boosters.
rolla wagn!
Postby bluemaumau » Tue Nov 14, 2006 6:19 pm
if you want any power youll have to turbo it, better to just put a 20v in it.
Postby Alex B » Tue Nov 14, 2006 6:46 pm
WHy even bother, as above just put a 4age in.
Postby thaphatty » Tue Nov 14, 2006 10:12 pm
plug and leads will only really make a noticable difference if yours are $&#$%.
best way to get power out of a 4afe is to drive it to work to save gas money for your next car
thaphatty
Postby KinLoud » Tue Nov 14, 2006 10:15 pm
there are a coupe of guys who have turbo'd their 4afe very successfuly
Do a bit of a search and you might find some good info.
Otherwise buy a 4age donor car of the same series/year and bolt all the goodness across.
Question...
What do you want? more power? better handling? bling?
Think about doing up the handling first... springs, shocks, replace swaybar bushes etc. This way it will be easy to cert when you go for more power.
Ken
Ham
021 408 863
Postby rolla wagn! » Wed Nov 15, 2006 5:48 pm
would like more power and quotes for engine conversions,to a 4age,its already lowered on 17s and handles well,tinted windows so doesnt look to bad either.
rolla wagn!
Postby bluemaumau » Wed Nov 15, 2006 5:51 pm
most people on here that have cars with different engines, have done it themselves so quotes will be hard to find, just cruise around local mechanics gettin quotes
Postby CozmoNz » Wed Nov 15, 2006 5:54 pm
To make power out of a 4afe.
How much u got?
cheaper mods include cold air intake, better flowing exhaust (not like the fe head can allow good flow anyway at higher revs).
Bit more $$$ and you could afford a very rungi turbo setup, nitrious.
and when you get a bit more $$$ you could replace everything to parts willing for boost (forgies etc), and a rather large turbo off the side, along with a new ecu :).
my suggestion for bang for buck. Nos.
Rayne For President!
CozmoNz
Postby rolla wagn! » Wed Nov 15, 2006 6:04 pm
got next to no power at the moment,would extractors and exhaust maka a difference,does anyone know of any one who has extractors to fit a 4afe,how do i put a cold air intake in,is it just a pipe to the front of the car from the air filter.
rolla wagn!
Postby rolla wagn! » Wed Nov 15, 2006 6:20 pm
what about pulleys or cams?
rolla wagn!
Postby Alex B » Wed Nov 15, 2006 6:49 pm
What about them? Your going to spend more money than making it 4age and get less preformance. To make the most of Cams you need a new Ecu. That alone would be more than what it cost to put a 4age in.
Postby blackie » Wed Nov 15, 2006 9:34 pm
do not work a 4afe... do not do it..
there wouldnt even be aftermarket extractors for 4af... even if they were, they would be making like 2hp. utter waste of time.
no.
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1892
When my bros call.. dey get hit wit da chinnggggaayyy
blackie
Postby jeremiahnz » Thu Nov 16, 2006 7:48 pm
For extractors you can use the 4-2 part from a 7afe then the 2-1 part from a Levin.
Turbo charging the afe engines seems to work well for a street car.
jeremiahnz
Postby Punter » Thu Nov 16, 2006 10:33 pm
blackie wrote:do not work a 4afe... do not do it..
Listen to this man.
A 4age swap is not hard, and its not expensive.
Even if your not doing it your self, it will work out cheaper than messing with the FE.
Punter
Postby Adamal » Thu Nov 16, 2006 11:39 pm
Just put on a T88 turbo and you'll be fine. You won't have to change anything and the stock ECU will handle it. You'll be good for about 35psi. No worries.
Please let it also be noted that I am talking out of my ass :)
Postby Alex B » Thu Nov 16, 2006 11:40 pm
You would never come on boost so stock ecu would be fine :lol:
Postby Chickenman » Thu Nov 16, 2006 11:47 pm
Nah don't listen to the doubters!!!
Lotsa people turbo fe engines and the cam design lends itself to good spool and drivability down low. (be good around town etc)
running 5-8 psi would be pretty fun and if it all blows up you'll still have all the turbo bits to bolt onto a 4age if you so wish.
Baby Jesus
Chickenman
I Am The Walrus!
Postby sergei » Thu Nov 16, 2006 11:59 pm
or get another FE off picapart for real cheap ;)/
heh
Postby ezy10s » Fri Nov 17, 2006 8:02 am
just drop a whole 7afe in it- 1800cc's. then turbo that if you are still wanting more, been done before wth good results. Just ask TWSTD his carib was a beauty
Member #244
Gone fishing until further notice
ezy10s
Postby rolla wagn! » Fri Nov 17, 2006 5:11 pm
haha,trying not togo turbo as iv had to much trouble with them,4age conversion sounds like the go.
rolla wagn!
