4age, 4agze turbo thread (General Discussion)
Postby Mr Revhead » Mon Nov 27, 2006 9:45 pm
for an aw11 i reckon w2a would be hard to improve one
for a stocker a legacy one is fine, a GT4 one is better though
Postby Caveman » Tue Nov 28, 2006 11:22 pm
Well looks like the stock c52 4age clutch sucks, im upgrading to an exedy button clutch. What do all you guys use?
AW11 Track Toy
Formerly known as 1998
Caveman
Postby IH8TEC » Tue Nov 28, 2006 11:54 pm
3 puck solid center with 1900lbs pressure plate. it's harsh for stop start traffic, but i don't care cause when it grips it grips and doesn't let go.
it's better after the drags though i must say, and the only shuddering is on initial taking off in 1st.
Postby Mr Revhead » Wed Nov 29, 2006 8:42 am
i supposedly use a stock cover and brass buttun puck plate. iv never had it out and thats what the guy who last did a clutch said wa sin there.
its certainly a lot faster on the uptake than a stock clutch
thats in a 9.4:1 4age running 8psi from a sc12
Postby Caveman » Wed Nov 29, 2006 6:20 pm
Ive got an exedy 4 puk cermic plate with a heavy duty cover, not sure on weight but probably not 1900lb, I think they are about 50% stiffer than stock
AW11 Track Toy
Caveman
Postby flygt4 » Wed Nov 29, 2006 6:22 pm
standard gze disc with a bit of extra clamping pressure :lol:
is only just starting to lose a bit of meat now , after 2 drag meets , 1 track day, 3 lengthy dyno sessions and 18 months of street abuse.
flygt4
Postby CAMB01 » Wed Nov 29, 2006 7:51 pm
I'm using a brass button disc with a 1800lb pressure plate, pedal is quite heavy and is really bad in stop start traffic.
Never had any problems, but i am only running 10psi from a SC12.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby bluemaumau » Thu Jul 26, 2007 11:35 pm
is anyone here running silvertop rods in there 4agte?
rods
Postby ezy10s » Fri Jul 27, 2007 9:49 am
bluemaumau wrote:is anyone here running silvertop rods in there 4agte?
these are the same as ae101 ze rods
Member #244
Gone fishing until further notice
ezy10s
Postby bluemaumau » Fri Jul 27, 2007 2:27 pm
well you learn something everyday. worth shotpeening them?
Postby matt dunn » Sat Jul 28, 2007 7:33 pm
Yes me.
