Need help in auckland with ABV mod
Postby escortman » Tue Nov 28, 2006 10:27 pm
i may need to do the abv mod on my fx but it was a conversion i didnt do so lines go everywhere is there anyone in auckland that i could come and show,
4x4 toyota blizzard offroader
escortman
Postby thegreatestben » Wed Nov 29, 2006 12:20 am
Maybe of some use
thegreatestben
Postby escortman » Wed Nov 29, 2006 6:05 pm
ook yeh that helped but on mine half those lines arent connected :oops:
if someone isnt busy 2moro and i could come and show u would be awesome
escortman
Postby escortman » Wed Nov 29, 2006 8:25 pm
just had a better look at changed some lines over, i have a line that goes from fuel pres reg to boost gauge to intake manifold, the abv doesnt have anything connected to it and hasnt nothing to block it up. theyrs two outlets at back off throttle body up high that are joint together with some hose then down lower theres a hose blanked off which i think goes to the abv, i put a splitter in and ran a hose to abv but after doing this the boost wouldnt go over 5psi, so i changed bak and it ran up to 7.5 again i cant figure this out
escortman
Postby Rick » Wed Nov 29, 2006 9:23 pm
All the "abv mod" does is stops the bypass valve from acting like a blow off valve, it disables the ecu's control over the abv. Alll you need to do is run a vacuum hose from the abv to the intake manifold, and put a cap on the line that ran from the vsv to the abv.
Postby escortman » Wed Nov 29, 2006 9:26 pm
yeh i know but at the moment my car doesnt even run the abv but when i do put it on it doesnt go over 5psi
escortman
Postby Rick » Wed Nov 29, 2006 9:31 pm
escortman wrote:yeh i know but at the moment my car doesnt even run the abv but when i do put it on it doesnt go over 5psi
It could be a number of things. The abv may be stuffed, it could be leaking causing your problem.
It could be the belt slipping on the supercharger which would cause a drop in boost
Postby escortman » Wed Nov 29, 2006 9:37 pm
ook yeh thats y i want someone who knows wat theyr doing to have a look
escortman
Postby Crampy » Thu Nov 30, 2006 11:41 am
I could have a look. I had an AW11 with pulley kit boosting 14psi. I did the ABV mod and then eventually got rid of the ABV completely.
I could show you when I get that AE92 parcel tray I just bought off you on tardme :D
I think you're near by. I'm at the Air Force Base in Whenuapai.
You're in this area aye?
Crampy
Postby escortman » Thu Nov 30, 2006 3:57 pm
o yeh tru lol was that u
yeh im just in titirangi
escortman
Postby Crampy » Fri Dec 01, 2006 9:06 am
You're taking it to the drags tonight aye? Well if it's on of course, you never know with this weather.
Anyways, if you are there, I'll come and have a look see then. I'll be there with bells on (not literally).
What colour is your car? It's an AE82 FXGT?
Crampy
Postby escortman » Fri Dec 01, 2006 9:42 am
yeh hopefully weather stays good
its a grey ae82 fxgt has bonnet scoop and the paint on bonnet is crazy cracked,
escortman
Postby Crampy » Fri Dec 01, 2006 12:15 pm
Sweet.
Was that the one that was on tardme a wee while back?
Crampy
Postby escortman » Fri Dec 01, 2006 12:27 pm
yep
escortman
Postby Crampy » Fri Dec 01, 2006 12:35 pm
Sweet.
The first thing you should change on it, is put the ECU in the passenger compartment, not in the engine bay. From memory that's where it is and isn't really an ideal place for it to be. Electronics like that don't tend to like water and heat etc.
How does it go?
I was thinking about buying it, but funds didn't work out in time.
Crampy
