Spacing out wheels
Spacing out wheels
Postby fuzzilogyc » Fri Dec 01, 2006 12:10 am
I recently got some new wheels for my 91 fxgt, and the tyres rub ever so slightly on the back struts. What would be the best way to fix this?
I can chuck a 4 or 5mm washer in between the wheel and the hub on each of the threads and that will fix the problem, but is this dodgey?
Alternatively, i could get a spacer made up (but then i only need to space the wheels out about 5mm).
I don't want to do anything yet in case something goes wrong.
Would it be easier to just get a new set of wheels with (more? or less?) negative offset?
fuzzilogyc
Postby GTCRSHR » Fri Dec 01, 2006 8:40 am
repco sell some chinese spacers, i never had a problem with them, but they dont feel like they would last
theres a guy on trade me who makes great ones, i had mine made up from him no worries what so ever !
Nothing to see here ...
GTCRSHR
Postby Snoozin » Fri Dec 01, 2006 9:13 am
GTCRSHR wrote:repco sell some chinese spacers, i never had a problem with them, but they dont feel like they would last
Is that Chris??? If so he's a good mate of mine. Does some stellar machining.
Snoozin
Postby GTCRSHR » Fri Dec 01, 2006 10:08 am
im chris ! so many of us,
but im not sure what the guys name was now, he was some where out of auckland anyways but yeah great guy to deal with, and great quality as well, hard to find people like that,
GTCRSHR
Postby Snoozin » Fri Dec 01, 2006 10:47 am
Too many Chriseseses.
Nah this dudes in Feilding.
Snoozin
Postby Adydas » Fri Dec 01, 2006 10:58 am
Arnt they illigal?
Adydas
Postby Dell'Orto » Fri Dec 01, 2006 11:01 am
Technically yup, slip on spacers are. I dont think 5mm ones would be that much of a worry though, its when you get munters chucking on 20mm slip on ones without changing studs that you get issues.
Postby Akane » Fri Dec 01, 2006 11:12 am
I have 4mm chinese ones they're OK
If you weld them on to your wheel or hub then it's legal.
Your nuts must be able to wound 7 turns into the stud to be legal too.
Postby GTCRSHR » Fri Dec 01, 2006 11:27 am
Snoozin wrote:Too many Chriseseses.
yeah thats the one !
great guy, highly recomeended
he makes bolt on ones
the slip on ones are good for a few mm like the guy ones, but i wouldnt go much bigger than 5mm, (again depends on the length of your bolt) and how much thread there is
GTCRSHR
Postby fuzzilogyc » Fri Dec 01, 2006 12:49 pm
so what are these repco ones....? i might go have a look...
so gtcrshr, you had no problems with putting a 5mm slip on spacer on your wheels?
fuzzilogyc
Postby GTCRSHR » Fri Dec 01, 2006 2:17 pm
you have to ask at repco, at the counter...
i didnt have any problems, only ran them for a while while i was getting spacers made up anyways,
BUT i had plenty of thread as well
GTCRSHR
Postby Santa'sBoostinSleigh » Fri Dec 01, 2006 2:58 pm
youve probably got the wrong offset rims and/or tires that are too wide for the rim/offset
slip-on spacers are illegal yes
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby RED TOP MR 2 » Sat Dec 02, 2006 6:30 pm
you could use the small slip ons as youll only need a pair for the back i think there about $30pair on trademe.main problem is yor wof these will fail it.
RED TOP MR 2
Postby TWSTD » Wed Dec 06, 2006 10:22 am
We sell spacers and you get a TS discount :-)
AL
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Postby Si » Wed Dec 06, 2006 6:47 pm
just use a few washers on each studd. make sure you use the same thickness ones or the wheel will wobble......
nb dont try this at home.or work.
Current: , '96 SubaruImpreza
Si
Postby tomo1985 » Wed Dec 06, 2006 7:57 pm
dont use wshers you will snap studs. Just use a 3-4mm slip on spacer but paint it back so warrent people wont pick it up.
tomo1985
Postby astrae » Wed Dec 06, 2006 8:01 pm
There illegal, full stop.
You have to get them certed
Mine got left off my cert plate by accident and I failed a warrent. Got them on there now.
Suppose it depends if the person doing the warrent actually sees them... I've got open 5 spoke wheels so there easy to see.
astrae
