rear brake pads ae92
Postby deaf_rattle » Sun Dec 03, 2006 6:08 pm
I had a look at the rear brake pads on the ae92 fxgt
didnt have time to ass about so left it for today.
Its completely different to the front brakes..
So do you have to beeld the fluid in order to change the pads?
if not, how do you get the pads to release?
Postby CAMB01 » Sun Dec 03, 2006 6:18 pm
Make sure the hand brake is off :)
and instead of pushing the pistons back in on the calipers you have to wind them back in.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Jebus » Sun Dec 03, 2006 8:51 pm
Yep, ya need to bleed them. And as said above the piston screws back in, use pilers on either side of the piston.
Jebus
Postby deaf_rattle » Sun Dec 03, 2006 9:06 pm
ha yep, forgot abotu the hand brake.. will look again tomorrow.
Must be able to do it without bleeding the brake fluid surely?
Postby CAMB01 » Sun Dec 03, 2006 9:08 pm
You dont need to bleed the brakes.
Just remove and fit new pads, screw the pistons back into the calipers, reassemble everything, and pump the brake pedal a few times until the pedal goes hard.
Job done :)
CAMB01
Postby deaf_rattle » Sun Dec 03, 2006 9:21 pm
sweet, cheers dude 8)
Postby CAMB01 » Mon Dec 04, 2006 9:03 am
No worries man
CAMB01
