12a kp60
12a kp60
Postby 4agtepwr » Mon Dec 04, 2006 12:34 am
Who heres done it and what sorta work is involved to make them fit?
Just wondering how hard it is to make the rx7 s1 gearbox fit in a kp60 tunnel?
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby toyae86 » Mon Dec 04, 2006 9:28 am
it's not that hard rotor's are easy to fit the box should fit without to much hassle w55 will fit have a look at import x fitting the engine wouldnt be to much different to the ke30
if you get stuck pm me i can point you in the right direction
toyae86
Postby l1ttle_d3vil » Mon Dec 04, 2006 9:48 am
pretty sure they go straight in without any mods to the tunnel or anything. i know someone with that exact conversion (they didnt do it though) but ill see if it looks like they're tunnels being taken to with a sledge hammer :lol:
Postby RS13 » Mon Dec 04, 2006 5:40 pm
I have assisted with a 12A conversion into a KP60, its' reasonably straight forward, but mostly you need to consider what the car is going to be used for. Most kits mount the motor quite far forward, which means that you won't need to mod firewall to get it to fit.
But having such a light car with a relatively heavy 12A sitting too far forward of the centre of gravity makes for terrible handling. If you're looking to do this properly, I would recommend sitting the motor back as far as possible, which necessitates modification of the firewall and transmission tunnel, but this allows for a significantly better balance and handling. Don't forget a decent rear end and brakes as well.
Or, if you're just wanting a KP with a rota bro, just fabricate/buy a chassis-mounting kit (which basically means that you've got 2 plates bolted to the chassis rails/radiator support crossmember, which the engine crossmember bolts to), make up a custom gearbox crossmember, get a custom driveshaft made up, find an SA22 engine loom to splice into the KP loom, install an electric fuel pump and lines, set up the hydraulic clutch, mount coils etc, you're away.
You may want to invest in a few spare KP diffs, (it doesn't matter wether you weld it up or not, you're still only going to get about 3 decent skids out of it!) and perhaps sort some bigger brakes off another early 80's Toyota (I can't remember what we used.. may have even been AE85?).
So yeah. Hope you either got mad hookups or deep pockets though aye, anything rotary these days is getting damn expensive and hard to find.. I personally wouldn't do it again, with setting it up properly for cert, you'd be better off just going out now and spending your hard earned money on a series 4 or 5.. possibly even a batty!
Just things to take into consideration. :)
RS13
Postby 4agtepwr » Mon Dec 04, 2006 5:52 pm
The car was going to get my angry little 4agte in it with w55 but alas things have changed a little so that engine and box prob arnt going to see that car. It has a shorted celica diff with te71 discs and a F series lsd in it which was good for 300hp and 12.3s in another starlet. front brakes are....... well will be when vvega sends me my calipers :twisted: are 280mm vented bluebird rotors and twin pot turbo sw20 calipers.
So brakes and diff arnt going to be a problem. Yeah handling is a big thing to me, its not a skid car, and im and engineer well Automotive Machinest by trade- big way of saying i rebuild engines for a job lol, so making things isnt to much of an issue. Just haven't seen a rotary kp in the flesh before.
Anyone got any pics of any rotary conversions?
Cheers rs13 would be good to have a chat to you about it.
4agtepwr
Postby 4agtepwr » Mon Dec 04, 2006 10:49 pm
bump if anyones got pics im just keen to see some setups or info
4agtepwr
Postby RS13 » Tue Dec 05, 2006 7:03 pm
Sweet as buddy. If you've got any questions, throw me a PM, I'll do my best to answer them! :)
RS13
Postby myke » Wed Dec 06, 2006 1:44 pm
And this is what you should be doing to your starlet....
Myke
myke
Postby EarthwurmJurm » Wed Dec 13, 2006 12:41 pm
thats a rather large turbo.
EarthwurmJurm
Postby strx7 » Wed Dec 13, 2006 2:01 pm
WTF is that engine? looks like a shortened down JZ, or altezza 3SGE but it doesn't look right...............???
its an altezza engine and the photo has been mirror'd hence the master cylinder resivour is on the left in the pic..........
Postby mr pad » Wed Dec 13, 2006 3:25 pm
Hmm. Looks like a hilux engine to me?
mr pad
Postby Mr.Phreak » Wed Dec 13, 2006 3:40 pm
Yeah, looks rather RZish
Mr.Phreak
Postby myke » Wed Dec 13, 2006 5:18 pm
Myke
myke
Postby 4agtepwr » Wed Dec 13, 2006 7:04 pm
i think its a 3rz? hilux engine its on the microtech website if you search it some were, dose a high 8s, from the US i think prob faster now. F*&kin Cool little car
4agtepwr
Users browsing this forum: Bing [Bot] and 21 guests
