after much searching everywhere, I cant find any solid information...
apparently 4agze starter motors are not compatible with rwd gearboxes...
so if im running a 4agze in a rwd setup with a w55, what sort of starter motor will I need? will the one fitted to my standard bluetop engine/flywheel work? or are the teeth going to be different...
cheers.
