ae85 brake booster - bigger brakes
Postby panda_dan » Tue Dec 05, 2006 1:37 pm
I am running ae86 front discs and RPs13 rear discs in my ae85.
Is my standard ae85 brake booster up to the task?
If so - great.
If not - what will fit the bolt pattern as a suitable upgrade?
Obviously ae86 will fit and will be good enough. Cant find one though.
Gts-t skyline fit but i dont want to bash my strut to fit it in.
Any help appreciated
Danny
panda_dan
Postby Jebus » Tue Dec 05, 2006 5:15 pm
Yeh itll be fine, just get a new mastercylinder. I Run Cressida and VR4 brakes off my stock master and booster, work perfectly.
Jebus
brakes
Postby panda_dan » Tue Dec 05, 2006 5:16 pm
why do i need a new master cyl?
panda_dan
Postby Jebus » Tue Dec 05, 2006 5:17 pm
Cos yours is 20 years old.
Jebus
brakes
Postby panda_dan » Tue Dec 05, 2006 5:19 pm
Oh ok. Got ya
panda_dan
Postby spencer » Tue Dec 05, 2006 8:24 pm
ae86 one is the same i think looking at the two, dont need to worry about the booster anyway its only for an easy peda feel, its the master that does the pushing
spencer
Postby l1ttle_d3vil » Tue Dec 05, 2006 8:46 pm
but if you've going to buy a new one get a good one, and be prepared to pay. i paied $40 for one and it sh!t out in about a year. new ones are normally around $200+ though...
Postby SUBARUCONVERT » Tue Dec 05, 2006 11:19 pm
master cyls come in a range of differnt bore sizes, genrally the larger bore size the larger the braking system as u need to displace more fluid to push the larger or extra pistons. usually u can get away with no upgrade. but if u go from one extreme to another u can end up with a long brake pedal travel. and they can be very expensive!
3ST150
SUBARUCONVERT
master
Postby panda_dan » Wed Dec 06, 2006 9:01 am
There is nothing wrong with my old master apart from being 20yrs old.
Does anyone know if toyota do an overhaul kit? That way i would be able to re-co mine for a fraction of the cost of a new master cyl
panda_dan
Postby l1ttle_d3vil » Wed Dec 06, 2006 9:47 am
you can get new seal kits, about $25 from repco. not sure what they would cost from toyota but shop around anyway.
