Super Strut Suspension and 18" mags
Postby DVSFOX » Wed Dec 06, 2006 12:23 pm
Hi Guys,
Hey I was wondering if anyone could tell me if 18" mags will fit AE111 BZG Levin without too much trouble. I have super strut suspension (if someone could explain to me what this is as well, would be appreciated) - Ive looked in the tech area and I'm still a bit confused.
Thanks,
Sash
DVSFOX
Postby CozmoNz » Wed Dec 06, 2006 1:36 pm
Rayne For President!
CozmoNz
Postby BZG_UNIT » Wed Dec 06, 2006 11:44 pm
i should think so eh.. alot of clearance with my standard springs and 17s
1997 Toyota Trueno
1990 Toyota Trueno GTZ
BZG_UNIT
Postby DVSFOX » Thu Dec 07, 2006 10:49 am
Sweet, heres to hoping they fit, cause I was speaking to another guy that had 18" DTMs on his car (Same as mine) and he had to put 5mm Spacers in.
I shall just cross my fingers and hope they fit. 8O
DVSFOX
Postby Punter » Thu Dec 07, 2006 10:59 am
Width and offset would be the most important thing, I'd thing any thing wider that 7.5" would be a tight squeeze.
Punter
Postby DVSFOX » Thu Dec 07, 2006 12:13 pm
They are 7.5" not sure on the offset though. Man I'm kinda thinking now I should have got 17s.
DVSFOX
Postby aesc » Thu Dec 07, 2006 12:59 pm
As long as they are 7.5" wide and 40 offset should be sweet. On my ae101 I had 17x7.5's and there was about 1-2mm clearance to the strut. 18"s should be no different
EX AE101 owner
2013 Ford Focus ST
aesc
Postby DVSFOX » Thu Dec 07, 2006 1:03 pm
Ok, not to sound intirely blonde.. which I am.. I'm still learning about car stuff.. I'm good with most stuff but suspension confuses me. What is my strut? I know what my strut brace is, but other then that it is beyond me. and what makes my superstrut suspension different then normal suspension and can it be removed so I can put coil overs in?
DVSFOX
Postby 2LTR Rona » Thu Dec 07, 2006 1:21 pm
first point of call...start looking at this
http://www.carbibles.com/
2002 Altezza, 1974 KE25
2LTR Rona
Postby DVSFOX » Thu Dec 07, 2006 1:23 pm
Awesome, Thanks!
DVSFOX
Postby Steelo » Thu Dec 07, 2006 6:26 pm
18s fit, took me ages to find some that fit.
Mine are 18x7 with a 40 offset, any bigger pretty much won't fit.
Use spacers as a last resort, if you do; your wheel nuts may not fit on as they should (eg not meeting the required no. of turns)
18x7.5 with a 40 offset will most likely not fit.
2012 Subaru WRX
1985 Toyota Levin
2014 Yamaha MT-07
Steelo
Postby DVSFOX » Fri Dec 08, 2006 1:16 pm
Yours look Nice!!! Thanks for that, helps me out a lot, going in tomorrow to my mates mag place to test some 18s on, got a few sets in to give them a go. *crosses fingers that something is going to fit.
as for ages to find some, hopefully that isn't in my case, ive got 1 week to find some I like and get them fitted
Cheers All,
Sasha
DVSFOX
Postby DVSFOX » Sat Dec 09, 2006 4:40 pm
Well for the interim till i pick my new mags, we got on some 18" w/ 225/35/18s.
DVSFOX
Postby DVSFOX » Mon Dec 11, 2006 12:05 pm
Hey does anyone know what the exact offset is for the Levin? Would a 43mm fit?
DVSFOX
Postby Punter » Mon Dec 11, 2006 12:20 pm
Factory offset is +38 I believe.
And the factory width is 6" so you'll need a higher offset if you want to go much wider.
My rims a 6.5" wide with +40 offset and I have tons of room everywhere. (only 15s though)
Punter
