lexan were to buy it.
Postby fxgt race » Thu Dec 07, 2006 8:07 pm
have spare hatch which i an going to lighten and bolt on when i got to the track,i want to replace the glass with lexan,does anybody know a good place to buy lexan.
fxgt race
Postby KinLoud » Thu Dec 07, 2006 9:18 pm
Look here on Garage Dori for lexan thread (DO NOT believe some of the weight reduction quoted).
http://garagedori.com/forum/viewtopic.php?t=2710
Is it going to be for a road going racecar?
If not, then just buy some polycarbonate... much cheaper... I put 3mm thick in the back and side windows of my racecar.
Lexan is just polycarbonate with a special coating to reduce scratching. Be careful with polycarb and it will last ages (4 years on my racecar so far).
Ken
Ham
021 408 863
Postby strx7 » Thu Dec 07, 2006 9:31 pm
your nearest glass place should be able to supply you either lexan or polycarb - your choice
Postby Santa'sBoostinSleigh » Thu Dec 07, 2006 9:32 pm
what kinda cost is it?
i wanna start by replacing my rear quarters on my fx
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby KinLoud » Fri Dec 08, 2006 5:39 am
A sheet of 3mm polycarb cost about $280 trade about 3 years ago. I think lexan is 2 or 3 times this cost?
1 sheet did side and rear glass of my carina.
Ken
Ham
021 408 863
Postby Leon » Fri Dec 08, 2006 8:03 am
Warning: if you are going to be putting plastic glazing into a road going car, you *must* use Lexan MR10 and nothing else.
Postby JamesM » Fri Dec 08, 2006 8:56 am
thats my thread, and yes i was on the piss when i quoted those numbers. hehe. the bonnet is actually half of what i said.. i think i changed it? but other than that its correct. (remember the actual panels only have the outer skin thus why so light.)
yea if u not using lexan MR10 then its not that expensive. i think it was 690$ for a 1.2x2.5m 3mm sheet of MR10 and then i had to get a little extra on top of that.
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
